why fuck with it?
you do a compression test. you either got cracked ringland or valvetrain issues. Either way, the head has to come off. these cars aren't known for headgasket issues. a smart person would take the head off, inspect it to see if anything is broken. then go for a piston. |
(Post 7673829)
why fuck with it?
Originally Posted by ECaulk
(Post 7673847)
Or just replaced the motor because the cost to get to a new piston is approaching a new motor all things considered. He's not high mileage but hell he'd get an additional 100k miles from a new motor.
Originally Posted by exninja
(Post 7673857)
His quote for the LDK shipped to AK is still cheaper than what mine cost including shipping.
from ZZP. they since knocked off $500 from the price.
yeah, why even mess with it.
LDK it |
Also don't need the turbo from the LDK. Save 500 bones there.
Could also try negotiating the shipping cost. An extra $960 seems steep considering they do free shipping to lower 48. |
Originally Posted by nickate
(Post 7673805)
And btw... chances are if he detonated it via tune, bad gas etc... he knows this but is not sharing that info--- just straight to a new piston.
I'm getting a shipping quote for barging a new LDK from Washington to Alaska to see about a better shipping option. Hopefully ZZP will work with me a little. I'll consider doing a leak down test. I'm borrowing a better endoscope to peak around the engine with before taking the time to take the engine apart. Meanwhile I have my old Dodge work truck to drive everywhere. |
wait....where did you live before Alaska? Did you ever get a retune?
The LDK happened! Thanks everybody. The whole swap with new turbo and shipping ended up costing me about $3,000 from ZZP.
https://cimg9.ibsrv.net/gimg/www.cob...5aa7ec1e3d.jpg https://cimg3.ibsrv.net/gimg/www.cob...5bc8200f90.jpg https://cimg7.ibsrv.net/gimg/www.cob...46cd651225.jpg https://cimg0.ibsrv.net/gimg/www.cob...935a0b8277.jpg https://cimg4.ibsrv.net/gimg/www.cob...2e72aae8bd.jpg |
:cssNET:
Nice!
Anyway, I put 11 miles on the car doing a break-in procedure. No problems! Then I checked for leaks yesterday morning and saw my hydraulic clutch elbow is leaking. I thought I could get away with not replacing it because I put in all new clutch parts 15k miles ago. Not a big deal, just one more thing i have to order from ZZP. I've not been super impressed with ZZP's customer service. They could have made more money off me if they offered me some things I would need like exhaust gaskets, flywheel bolts, etc.
Also if you order a new engine from ZZP to be shipped 5,000 miles, all they do is set it on a pallet with some cracked 2x6's screwed around the oil pan. The forklift driver at the shipping company was nervous to even load it onto my truck. https://cimg2.ibsrv.net/gimg/www.cob...c481ac326d.jpg |
Originally Posted by royce777
(Post 7685280)
Upon installation, I removed the nipple rubber seal from inside the elbow and placed it on top of the clutch pipe as show in the photo. Then i pressed the elbow onto the pipe and installed the metal clip. It held enough pressure to drive 11 miles but leaked sitting the next day. I really hope a new elbow fixes it and I don't need to replace the clutch pipe.
I have a brand new elbow if you didn't order one already
(Post 7685383)
(Post 7673232)
You could source a single good LNF piston, pull the rod out and hone it with a drill hone then get some new rings. gap them and see what happens.
I wouldn't do that. but you could that was my suggestion. if you need to be cheap this option will work fine. just make sure you don't damage the crank taking the piston and rod out and lay a rag over the crank while you hone it. i've done this several times. i used to break stock honda pistons all the time when i was turboing them, its pretty easy to do this with the short block in the car. |
didn't read page 2.
motor looks nice hopfully it lasts. did you see what was wrong with the other motor? |
I still would suggest a retune since you moved to a different atmosphere
(Post 7685523)
Originally Posted by HGT
(Post 7685524)
I'm pretty sure he is still in the troposphere :lol:
Alaska is like its own universe of there |
