I wonder is there a list of Tunes some where i live in Atlanta & was thinking of Moding my car just have not made up my mind yet.
Forge BPV are NOT an upgrade. They are a pain in the dick and not worth the $150.00 at all. They are too stiff even on the lowest spring and cause BPV solenoid issues as they are slower compared to stock. The stock BPV is the best choice.
You should NOT run a vent to atmosphere BPV or BOV without a tune, on the OEM BPV solenoid, and a MAF relocate it HIGHLY recommended to avoid rich spikes from releasing metered air. When doing the MAF relocate you can simply cut the plastic wire loom open and pull out the wires to move the MAF plug to its new location. No harness or wire cutting is needed on the Cobalts. |
Good advice!
(Post 7587358)
Good advice!
I have had a dollar for every argument I have caught over my analysis of the stock BPV solenoid, MAF relocate and VTA on blow through set ups, I would have a free s257 swap on my car lol |
Originally Posted by Direnight
(Post 7587222)
(Post 7587222)
guys - havent looked at this thread much since i made it. any additions/changes i need to make to the OP?
Thanks! |
Post #52
Add to it that a BPV, BOV, or MAF relocate are not power adders. People seem to think they are. |
Affirmative. Idk why anyone thinks they are lol. They do sound cool though which is worth 5hp in my book ;)
(Post 7587487)
Originally Posted by blueLNFftw
(Post 7587254)
so if i understand this correctly the 3 bar map sensor just senses a more accurate boost pressure correct. And the HPtuner is that a specific brand or is the a couple of hptuners
Originally Posted by theamericono
(Post 7597341)
I have a 2009 4 Door Cobalt SS Turbo Silver i believe i put picks on my account if you wanted to see.
(Post 7587441)
What car do you have?
and what about us canadians that dont have access to Ethanol fuel? all we got in my area is 10% ethanol fuel of 92 and 94 octaine
Originally Posted by Scypheroth
(Post 7618850)
What process is required when switching from 93 to ethanol fuel?
Originally Posted by KINGMAROSS
(Post 7636330)
You can run E30 with just a retune usually. |
Gms1
If I had gms1 sensors do I need to get a custom tune for the effect or can I just install and I’m good to go? |
Originally Posted by LnFitness
(Post 7678575)
Originally Posted by Snail_SS
You will need a tune to run the sensors. Either the gms1 tune or a custom tune
Originally Posted by Pasierbek
(Post 7523173)
Wow what a great thread for an LNF beginner. Thank you for starting this up! One question though, I heard you have to cut your stock exhaust to install a downpipe. Is that true?
Also in regards to transmission, I heard the throw out bearing is not very durable. The TOB is really only an issue for people that replace the clutch. Some people install the new TOB wrong and it leads to issues |
Zzp's newly released upgraded HPFP and mongorats LT4 pump adapter kit should be added to thread.
Hey guys I live in Denver Colorado right now on 91oct pump has just few bolt on like downpipe zzp catless zzp bigger intercooler zzp trans mount and I have a intake from k@n have not put that on yet it’s my daily drive but my goal for it is like 305-310who and 330-340ftq To. Right now has the zzp canned tuned and did 285hp 314ftq on 20psi that all I can do pretty since I don’t have charge piping change yet will soon tho |
