Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LNF Performance Tech (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/)
-   -   LNF e47 injector limits (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/lnf-e47-injector-limits-267185/)
raver0789 Dec 11, 2011 02:41 PM
Wondering what the injector limits are on e47, stock motor, stock cams. Planning on running an efr on 24-26psi. Got away with it 434wtq on the stock turbo easily, obviously next year might be different.
Thanks.
Matt
Iam Broke Dec 11, 2011 10:06 PM
Log your fuel rail pressure and Injector duty cycle. If the pressure tanks under ~1100 psi at the torque peak and Inj DC climbs over 40 % you are nearing the limit of the stock fuel system. You can ramp in the boost easier under 4k to help but your torque will suffer.
Chevycobaltss3 Dec 11, 2011 10:11 PM
Also it depends on the amout of air your pulling through that will limit you!!! Exactly like (Iambroke) Said But the limitations are also the airflow
Iam Broke Dec 12, 2011 05:45 AM
Increasing the diameter of the intake piping at the MAF sensor will lower the MAF freq the ECU sees if you overshoot the range of it. There is a MAF freq limit but I forget what it is. Perhaps James knows.
I think you will run out of fuel on the stock system before you run into MAF freq issues but it depends on the setup.
Chevycobaltss3 Dec 12, 2011 10:26 AM
The hertz I think are 14000-15000..
RyRidesMotox Dec 12, 2011 11:10 AM
Mine would lose pressure in the midrange as soon as boost peaked. I would throw low pressure codes. Term2 has ramped in the boost and torque but even then, I still spin 3rd. I can only imagine that the larger turbo may actually be ok in the midrange, but the higher airflow would make the pressure drop higher in the rpm range. But I'm thinking the higher rpm boost hit might actually allow the HPFP to build pressure. Still I think you are going to run out of fuel OP. I am hitting the max the fuel system will sustain on E47 on a stock turbo. If/when I turbo swap, more fuel will be needed.
raver0789 Dec 12, 2011 02:21 PM
Thanks for the input everyone.
paintballerr78 Dec 12, 2011 03:45 PM
Idk if this will help but im running a 5557 turbo on e47 and i was running 28lbs without running into fuel problems. Then again 2 totally different turbos
raver0789 Dec 12, 2011 04:23 PM
Yeah. The lag of the 5557 probably saved you. IDK how the hp fuel pump will respond to 26 psi of insta boost down low from an efr. If i get the byt efr 7064 it might be really hard for it to keep up with 55lbs of airflow.
paintballerr78 Dec 12, 2011 10:00 PM
yeah i want to get a efr but i cant find any...i hit full spool at around 3800
ATLsilverSS Dec 12, 2011 10:16 PM
byt has one
krispy Dec 13, 2011 12:13 AM
Originally Posted by Iam Broke (Post 6199726)
Log your fuel rail pressure and Injector duty cycle. If the pressure tanks under ~1100 psi at the torque peak and Inj ms climbs over 40 ms you are nearing the limit of the stock fuel system. You can ramp in the boost easier under 4k to help but your torque will suffer.
Max injector pulse width depends on rpm, @ 6000 rpm there is an ignition even every 20ms for any given cylinder. Generally with PFI injectors after ~90% duty cycle the quantity injected goes non-linear, haven't seen any DI injector data, it might be able to handle a slightly higher % due to the rail pressure helping to close the armature.
Iam Broke Dec 13, 2011 05:42 AM
With DI, we have a limited window. At the torque peak in the 3-4k range experience has shown me that >40% IDC is too high and inj window misfire will start happening. It's a different beast than port injection.
The fuel pressure drops and IDC climbs trying to compensate as we run out of fueling on the stock system.
FrossB Dec 13, 2011 06:07 AM
So i assume that will throw misfire codes on all cylinders?
krispy Dec 13, 2011 05:31 PM
Gotcha, I was just confused when you said 40ms, 40% DC makes more sense.
Its too bad I haven't done anything with DI at my job, I'd love to learn about it.
Iam Broke Dec 13, 2011 06:36 PM
Nope, it doesn't, just starts popping back in the intake.
Iam Broke Dec 13, 2011 06:40 PM
Ya, I mistyped before. Fixt it. Sorry.
