Lnf map sensor problems
1 Attachment(s)
So what I want to know is if the MAP sensor the same as the boost/turbo sensor?
About a week ago I finally replaced the clutch/tob/flywheel/rearmain/and differential seals on my Balt, after driving my car ever since i started it back on i have had cel i didnt want to worry much until I wanted to boost up and got surprised of only doing under 5 psi and once I release on the gas pedal there is like a sound of air escaping back to the intake(stockairbox) which i had never heard before in the almost 1yr of having my car ,so I am checking then for codes which are p0238 p0236 p0098 p0030 p2199 Which would come to be with the map sensor/boost sensor if I am not correct, so I pick my car up go under it take down the cold pipe and find that MAP sensor is disconnected and broken, I wondered how and figured out that when o drop the crate the radiator fan must have broken the sensor,I figured this would be my under 5psi problem?or are there any other things I should check for? |
1 Attachment(s)
Just fix the sensor and see if your problems go away if not then start looking somewhere else
Originally Posted by Jay P.
(Post 7487527)
I found out after when i took the whole pipe off
Lol oh. Well there is ur issue
