LNF Oil Pressure Gauge install
pressure gauge i used was autometer Sport Comp 105-3327. Auto Meter 3327 Auto Meter Sport-Comp Gauges
pics of sending unit
I would prefer to grab a reading from the top end - where you will see the lowest pressure...
and when I do this, I will do my best to hide it...
on a related note - does anyone have any opinion on an oil pressure gauge which most closely resembles the appearance of the stock boost gauge??
https://www.cobaltss.net/forums/how-...bo-mod-275645/
Just out of curiosity can you tap the galley plug just under (drivers side) the oil filter location? I am installing on an LDK engine and there are no galleys on the back of the block. But there is one under the oil filter. Can this be a place to hook the sending unit? I don't really want to take out the stock sensor.
#36
#38
#39
So did i do this right its a ldk? And is the computer going to act crazy now? Its in the factory sender location
#44
please see the link I provided in my last post, or the link provided in post #12.
there are plugs that go along the front and back of the block;
you can in theory use any of those plug spots - but in my opinion the ones on the rear are too tight (close to exhaust/turbo) to use, so I used a front plug;
the linked adapter allows you to pull a plug, and directly connect the aftermarket sender to that adapter.
I don't know if I have a picture, but I will look on my computer to see if I have one.
What I do recall is that you need to grab a source from below the head, because there is an inline restriction which lowers oil pressure in the head - and will give "false" low readings if used - so that's why everyone is using a plug/spot on the block.
#45
this is a screenshot of the LNF engine from CED;
I added red lines to depict where the oil system access plugs are;
At least I seem to recall there being four plugs;
The fourth plug location isn't visible in that image;
Part #110 is the plug that will be installed in all locations;
I used the one closest to the timing chain, because that put it the furthest away from anything else;
I could be wrong, but I believe that the LDK ect, ect have a revised oiling system - I found images on my computer of other replacement engines, and they didn't *appear* to have these access spots.
If I can help any more, please let me know.
09BlkCrusader
09-09-2015 04:47 PM
