Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LNF Performance Tech (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/)
-   -   Lnf problems :( (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/lnf-problems-318888/)
reybalt Aug 26, 2015 09:06 PM
Lnf problems :(
Hey guys, my 09 SS has been having problems. The car has a misfire and the rpm needle drops and goes back up when it's on neutral coming to a stop. Could it be a dirty throttle body? Or dirty maf? Btw. It's running lean and it has a brand new ldk installed. Any help will be great. Thanks
footballplaya3k Aug 26, 2015 09:11 PM
Lnf problems :(
Have you boost-leak tested?
reybalt Aug 26, 2015 09:23 PM
Lnf problems :(
I haven't. I will do that tomorrow. I recently installed an aftermarket lower charge pipe and then all these problems started to occur.
footballplaya3k Aug 26, 2015 11:07 PM
Lnf problems :(
That could be it. What charge pipe?
reybalt Aug 26, 2015 11:09 PM
Lnf problems :(
Hahn
footballplaya3k Aug 27, 2015 12:38 AM
Scary. Watch out for rust.
Sl0wbaltSS Aug 27, 2015 02:32 AM
Running lean on a new ldk? get retuned. Def don't stay on oem LNF or gms1
reybalt Aug 27, 2015 11:08 AM
Lnf problems :(
It's currently on gms1. Why don't you recommend the gms1?
ECaulk Aug 27, 2015 11:13 AM
Dont listen to him.
The rpm dropping is most likely connected to a vacuum or boost leak probably from the lower charge pipe. Start there, when you installed the LDK did you use new AC Delco plugs? And then the break in period was followed?
reybalt Aug 27, 2015 11:25 AM
Lnf problems :(
I bought the ldk long block from zzp. It already came with spark plugs but i have (new) spare spark plugs. However i did leave my aftermarket c.a.i. installed. Not sure if that can cause it.
ECaulk Aug 27, 2015 11:26 AM
Which intake?
reybalt Aug 27, 2015 11:28 AM
Lnf problems :(
Aem cold air intake.
ECaulk Aug 27, 2015 11:42 AM
Lnf problems :(
Do you still have the stock one kicking around? If so put that on till you can get the issue straighten out then try the AEM intake again
umrdyldo Aug 27, 2015 12:00 PM
For sure sounds like a boost leak probably in lower charge pipe.
Do you have any way to monitor the car? You should be watching your fuel trims and such.
Especially after a new install. You have no idea how it's running and could hurt the new engine.
Sl0wbaltSS Aug 27, 2015 11:43 PM
I had a huge hole in my OEM intercooler and it idled perfect and AFR's were perfect. Just no power :lol:
