Lower 3 Bar Map Install
Has anyone else had issue with this like I am? The lower one doesn't fit either direction I try and put it. One way it hits the AC line or pump the other way it hits the fan. What did you guys do?
Well, first off, what brand of cold side charge pipe do you have? It'll be in a little bit different position for each brand pipe.
If you have Hahn lower piping you're pretty well screwed, lol. Get the zzp lower piping. It relocates everything up.by the throttle body.
Yea I have the Dejon cold side pipe. ZZP is the way to go huh? Damn...lol
I have the dejon cold side pipe and I had to readjust it to make it work. It's a really tight squeeze but it'll work. I electrical taped over where it might rub just in case.
