Meth Wiring???
Old Oct 3, 2011 | 06:54 PM
slvrred-'s Avatar
Exclamation Meth Wiring???
I tried to search and couldn't get a clear answer to my question. I just finished up plumbing the devil's own stage 2 meth kit and now i have to move on to the wiring part of it. Now i'm the type that HATES wiring and everything that has to involve me doing it, lol. The instruction on pretty clear on what to wire it all to but it is in all general a universal kit. Can anyone help me out and maybe show me what they wired everything to? I'm also confused on what 0-5 volt boost sensor i should wire the kit to. I'm guessing the MAP sensor but i'm not 100% sure. Thanks again guys.
Old Oct 3, 2011 | 10:57 PM
tomj77's Avatar
i do believe its the map on the manifold
Old Oct 4, 2011 | 09:58 AM
slvrred-'s Avatar
I was figuring that but wanted to be totally sure. Itd also be helpful of which wire I have to tap into.....
Old Oct 4, 2011 | 10:03 AM
ATLsilverSS's Avatar
what is the model of your kit? is it the 2.5 bar kit or dvc30?
Old Oct 4, 2011 | 10:08 AM
JsavageSS/TC's Avatar
If only you lived near me. I'm a master at wiring and do very clean installs. lol
Old Oct 4, 2011 | 10:11 AM
i think the correct wire is grey.....measure with a multimeter if you have one. with the ignition on and the car not running it should measure 1.8 to 2.8
Old Oct 4, 2011 | 10:46 AM
slvrred-'s Avatar
I believe its the dvc30 kit. It's the stage 2 kit on there web site. If that helps any.
Old Oct 4, 2011 | 10:54 AM
they have a couple different stage 2 kits....they 2.5bar kit is designed to get the signal right off a 2.5bar map sensor. my understanding from devils own is if you have a 3bar kit then you have to have some kind of adapter....not sure. but like i said above i believe it is the grey wire but if you have a multimeter test them all for certain and with the key turned to the on position and the car not running the wire that reads between 1.8 and 2.8 is the one you want to tap
oh you have a 2.5bar kit cause the dvc30 uses a boost line
Old Oct 4, 2011 | 11:00 AM
BYT*SS*TURBO's Avatar
Pin 3 - L GN
Old Oct 4, 2011 | 11:03 AM
slvrred-'s Avatar
Then I guess I have just a 2.5 bar kit. I don't have any other fittings or adaptors, just the one wire they say to wire to "boost pressure swtich"
Old Oct 4, 2011 | 11:09 AM
slvrred-'s Avatar
Originally Posted by BYT*SS*TURBO
Pin 3 - L GN
So it's the light green wire on the end of the three pin connector nick?
Old Oct 4, 2011 | 11:46 AM
Pin 3 - L GN
haha thanks nick....ive looked at it but couldn't remember which one it was
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 07:39 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
