My build
Well drove down to Ohio, met Chris Miller and picked up his block. Nice guy, block looks good. Going to be putting it into my Saturn Sky Redline i picked up. I did have a Cobalt SS Turbo but sold it and am moving on to RWD.
My build will be: Chris Miller's LDK built motor: Gen 3 LDK block. 2.0 liter with 4 thou PTW clearance Wiseco pistons ZZP rods GM bearings ZZP neutral balance shafts Stock crank ATI OD damper 2.4 ported throttle body ZZP ported head ZZP springs with titanium retainers ZZP stage 3 cams with actuators for 8k RPM operation 5th Injector with 80lb injector Opel Injectors Turbo: I've gotten AGP to make me a custom S363 turbo with a .63 backside housing. 4" anti surge. I didn't do a huge backside housing because I wanted to help spool a bit. I'm hoping the .63 housing won't kill it too bad. I'm hoping for spool in the 5k range. With an 8k rev limiter, it should work well. Clutch: I haven't decided on a clutch, although I'll need a strong one. Extras: I'll also be using a custom manifold to fit this large turbo. As well custom charge pipes with BOV, and using Werk's intercooler most probably (because ZZP doesn't make one for the Sky), and lastly custom downpipe and dump tube. Along with this, a 46mm Tial Wastegate, ZZP Knob Style Boost Controller. Add a WOT box, Slicks on the rear, a roll bar, and it'll dance. I'll keep everyone informed as to how it goes with everything. There is more drivetrain loss for sure, just from having this car tuned on the K04. So i'm not sure how much power I will make. I'm hoping for high 400s to 500 on pump and between 600 to 700, Dynojet, on e85 ethanol. Gotta figure out how to wire an electronic switch on this 5th injector, so I can turn it off when running pump, and turn it on when i'm running e85. As I'll only be doing that for track. Let's hope the rear diff doesn't explode. Ha. |
Only 600-700 on S363?? I was following that other high hp LNF RWD build then he fell off the planet so I'm happy to see a new one pop up. When do you think you'll have it done?
Originally Posted by raver0789
(Post 7417699)
My build will be: Chris Miller's LDK built motor: Gen 3 LDK block. 2.0 liter with 4 thou PTW clearance Wiseco pistons ZZP rods GM bearings ZZP neutral balance shafts Stock crank ATI OD damper 2.4 ported throttle body ZZP ported head ZZP springs with titanium retainers ZZP stage 3 cams with actuators for 8k RPM operation 5th Injector with 80lb injector For a turbo I've gotten AGP to make me a custom S363 turbo with a .63 backside housing. I didn't do a huge backside housing because I wanted to help spool a bit. I'm hoping the .63 housing won't kill it too bad. I'm hoping for spool in the 5k range. With an 8k rev limiter, it should work well. I haven't decided on a clutch, although I'll need a strong one. I'll also be using a custom manifold to fit this large turbo. As well custom charge pipes with BOV, and using Werk's intercooler most probably (because ZZP doesn't make one for the Sky), and lastly custom downpipe and dump tube. I'll keep everyone informed as to how it goes with everything. There is more drivetrain loss for sure, just from having this car tuned on the K04. So i'm not sure how much power I will make. I'm hoping for high 400s to 500 on pump and between 600 to 700, Dynojet, on e85 ethanol. Gotta figure out how to wire an electronic switch on this 5th injector, so I can turn it off when running pump, and turn it on when i'm running e85. As I'll only be doing that for track. |
Originally Posted by KMO43
(Post 7417703)
Depends when my mechanic can get up and running. Work on it over the winter. I want it done by April 1st. |
Originally Posted by tomj77
(Post 7417705)
that's not hard, black wire on the controller of the 5th injector to ground, power wire to switch wire , other switch wire to accessory power wire. very easy . sick build
Looks like you should hopefully be able to get your 700hp from the compressor map and dynos I saw. What kind of boost do you plan on running to hit your goal?
The compressor map will be different with the .63 housing. It'll choke up for sure and never reach peak flow. I'm going to aim to get it working on pump gas first, make 500, and then up the boost. 600 or disappointment lol.
I figure the block can take 700whp and 45psi with ease. |
(Post 7417718)
The compressor map will be different with the .63 housing. I'm going to aim to get it working on pump gas first, make 500, and then up the boost. 600 or disappointment lol.
Problem is though nobody thinks about reliability, what works simply, over and over.
Journal Bearing turbos are easy to fix cheaply. Borg Warner S300 turbos are built like tanks and rarely break. The turbo was cheap. I don't want extravagent. I want something that works over and over. Plus i think it's good to keep torque low and flat instead of spiking, keep load off the trans and stuff. |
(Post 7417720)
Journal Bearing turbos are easy to fix cheaply. Borg Warner S300 turbos are built like tanks and rarely break. |
Yeah but problem is there is about 40whp of drivetrain loss i figure I have to make up on my platform. Hence I chose something large.
Are you going single scroll or twin with a quick spool valve?
Normal Single Scroll.
As long as she is in around 5k, i'm sure she'll be good. I'm hoping she'll spool as quick as an s262 in a .70 with a little extra kick. |
(Post 7417727)
Good to see a thread on this. I'll be following the updates. Everything should be capable of meeting your goals. Get to work! :)
Subd
(Post 7417699)
Can't wait to see this built up. |
Posting to follow, good luck.
(Post 7417737)
Ya the HP record is on the s262 for the LNF. What tires are you gonna be running?
I won't be breaking records. There is more drivetrain loss to make up like I stated before. And at that point I'll be mixing half e100 and 116 or even diluting it more which may be complicated and I may just say fuck it. Just want to go to the track. Run e85. Kill kill kill. |
There is something to be said about a car that can be driven at any given time as much as you want that can kick ass on the daily and be reliable. Not that a record breaker isn't fun, but a streetable consistent car that makes respectable power is much more fun in the long run. You've got the right plans for the car :twothumbs
Exactly. I bought the truck to trailer it there and be able to take it home should something happen. Shit always happens once and awhile. But if it's becoming a headache time and time again it's not fun. Running 500whp on e85 on the track and then turning up the boost as the day goes on and the car making it through the day would be killer.
(Post 7417825)
I don't think anyone has blown an axle, rear end, or a trans except for that 2jz guy. He blew his trans. The syncros can go. But the trans is good for 100 lb ft more than a 4.45 I believe.
(Post 7417918)
Nice to meet you Matt, I am excited to see what comes of the sky. 600 whp rwd 3000 lb car is going to be sick as hell.
