My ZFR review
The F40 + zfr set up would be kickass but for just the trans setup is like 4k. Crazy expensive compared to a 4.45 or 4.05. The 4.45 is so intense though. The pull is incredible and still wonderful. Just wish it was a 6 speed from to time cause long trips are loud cause it is revving so high on the highway.
While I'm not the biggest fan of Mitsubishi turbos, they really aren't nearly as bad as they're made out to be around here. It's primarily an issue of knowing the turbo characteristics and tuning the vehicle accordingly. The low end surging that is common in the 20g isn't related to the adaptor Hahn uses or even issues with the stock manifold as some might try to claim. It's simply an inherent characteristic of the turbo. If you try to push 20+psi below 4000rpm you are far below the turbo's surge line at that point, which will cause the turbo to surge. Anyone who can read a compressor map can clearly see this. Simple solution, slow spool time. Tons of testing and tuning isn't needed to determine this. I'm not defending Hahn or the 20g and saying you should have just slapped a 20g on there instead, because clearly you ultimately ended up with a superior turbo imo. I am however just trying to clear up a terribly incorrect misconception about the turbo that some seem to have.
It really doesn't take a dump. I went to Hershey last year with the zfr and 4.45s and still manged 35mpgs while doing occasional highway pulls. Before leaving I filled up with 12.2 gallons(ya not completely empty, but you get the point) went 430 miles and filled up at a gas station on the way back and got 12 gallons iirc. Still pretty damn good. Lol. Staying at 70@3k is key.
Edit:
lol every thread i've just searched you posted in.
Ahhh found it... Quote from James in lnf hahn s20g dyno thread:
"25lbs on a 20g isn't technically 400whp. If timing is great and the boost is efficient then yeah. But lnfs are different within the kit. The 20gs get massive surge on the lnfs with Hahns kit . I've replaced the adapter to a smaller bend and I got less surge and it gained more midrange of course but a lot is timing and boost up top"
"Now why would I do the mix. Because not everyone has the 91 or more. And the gas station didn't have 92 only 91 89 and 87 so I went with a more baseline of what numbers can be hit. I even explained myself on why I did it in the thread. My car is actually quicker now then it was then and I'm on 93 octane 14* mid and 17.5 topend (because I'm not getting kr) but also because I keep my 26 til 5k which i have it go to 24lbs then at 6k I raise it to 26 BECAUSE SOME SURGE!"
Next post was by lazaro:
"Yea my tubo surges like a mother"
Heres the link to the thread:
https://www.cobaltss.net/forums/08-1...80/index3.html
And just for reference, I'm a big fan of the 18g, 20g, t67 25g, etc, they do pretty well and are pretty cheap/ reliable to boot, just maybe not the best match for the LNF.
I have a bit of a love/hate relationship with mitsu turbos really. They aren't by any stretch the best turbo around, but they are inexpensive and relatively reliable for the most part. Some lnf's I've dealt with took perfectly well to Hahn's 20g setup and others basically hated it and more or less crapped it out.
As far as surging goes. Generally speaking, the most common issue that would cause surging mid range or up top could be basically the turbo pushing more air at a given point than the engine can take in. Possibly due to a restriction, or even the throttle plate closing. Sometimes even the incorrect bov setup can sometimes cause what looks and sounds like surging, but is really just essentially the bov and turbo flow fighting one another in a game of flutter. I went through some random 20g logs as a reference and I'm really not seeing any issues with surging up top. I am however seeing quite a bit down low if boost, cam timing and other factors aren't set up just right. Another issue they tend to have more so than just about any other turbo on the lnf are high egt's. Granted there is no real pyrometer to go off of unless one is installed aftermarket, but you can clearly see it becoming an issue up top with an apples to apples comparison using the stock sensors the log supports what the egt's are showing.
I can agree with that, thanks for your insight. If the optimum torque and optimum timing tables along with the PID tables aren't setup correctly, they can definitely cause a restriction trying to fight the throttle plate by closing it in the upper range, and yeah cam tables too I can imagine. All of these tables on mine are very far from stock.
Great review. I am sure you have easily achieved your goals. A friend of mine had a ZFR with the bolt ons like you and was on E47 and 25-26 lbs and when we tuned it, the car was out of injection window at 5900 rpms, but he liked the power so didn't want to turn down lol, but it made 420whp and 410tq.
Did you guys try shifting the injector window? Or just leave it alone? I'm not having any issues yet, but haven't been able to go above 5800 rpms many times in gd Houston traffic, and the few times i did, i wasn't logging. I'm getting to 7.3ms on my injectors around 5200 rpms which is kinda high, but fuel pressure is staying steady up to 5800. My injector timing tables are stock but my cam tables are far from stock. I think i may shift my injector timing a bit, still doing research on it though trying to see where an ideal shift would be depending on my cam timing, I don't want to guess and make a blind shift on the injectors lol. The cam tables are pretty damn good though, my MAF and VE readings are pretty much dead on matching to one another.
To do list:
1.) Injector timing research
2.) aeroforce interceptor
3.) zzp stock intake cam with fuel lobe
To do list:
#36
I know you do have to mess with it to get it perfect. It took a good solid 4-5 revisions until we stopped my problem. My biggest issue was right around 4800-5k when the car would buck a tad. There was times when getting my car revised it would happen between 4.5k and sometimes up higher like around 5.5k. It was a horrible time at getting it perfect. It also has to deal with the WG canister installed on some of the zfrs that were causing a slower than average spool compared to others.
#37
Any idea which way the injector timing was shifted? I'm seeing two different sides on hptuners forums, one is saying narrow the window by starting the injector later and another says start the injection earlier. Im going to try to lay out my cam timing to see what would be ideal.
I have no issues so far like that though, just worried about the upper rpms injector ms. Plus im only boosting 22 psi up to 4500 rpms, so that why im probably not seeing an issue like you were.
#38
#39
I gotta get into it more and figure out somethings. I was tuned by term2 and now he is out of the game so I'll be looking to do it myself with the of some guides. Hopefully. :/
#40
To do list:
To do list:
#41
I'll have to look when I get home. I noticed it varying a couple times but never actually looked at the final product.
#42
Injection window and/or rail pressure drops shouldn't really be an issue up top with the right injector timing set up even at that boost level. The only time it becomes a prominent issue is in high torque area, such as 3500-4700rpm, where fuel demand is greatest.
There's part of your issue right there. Even without my 5th injector spraying I hardly ever saw much more than 7ms beyond 5k and that's with e47. On 93 you shouldn't see much more than 6ms that high up in the rpm range especially only running 22psi.
#43
Do you really have to lay out your cam timing and find the correct place to start injecting? Or is there a simpler way to do this?
And thanks for the help so far.
#44
well i guess i answered my own question, mapped out my cam and shifted my injection timing......and quite a difference it made....... Im at 6.9ms where is was at 7.3 before shifting it, and 6.4ms and 6000rpms. No issues i saw and it actually feels smoother. This is as much as i could push it with traffic, and i lowered boost a tad. Theres also an example of how good the zzp smaller intercooler is at keeping IATs in check.
#45
Also wanted to share, I got my KY clutch for $86 cheaper than TTR offers.
I'm glad i got mine before TTR has a hissy fit about another guy undercutting them on the price and tries to have them remove it from their site lol
Bought my kit from Kruman Custom Cars Performance located In PA, great service.
TTR : $430
KY Clutch - Chevrolet Cobalt/HHR 2.0L F35 Trans Stage 3
KCC Performance: $344
TTR : $430
#46
Update:
Still going strong on the ZFR, now minus the E47, back on 93 octane. 4.05 tranny still holding up, KY stage 3 still holding. Still a fun daily, front tire sets since ZFR, 2 sets down lol.
Back when she was running E47 and on the way home from work:
#48
It's just interesting how polar opposite experiences people can have with the same exact products. The thing is, I was reading up a bit more on these southbend clutches and it seems as though the disk springs are a bit of an issue. I'm not saying their a bad clutch, but I'm also not saying they're worth every penny of that $700+.
I just hope yours holds out a bit better. I'm sure it will, but just maybe keep vigilant for if the trans starts to seem like it's hard to get into gear at times.
#50
I wouldn't be too worried about the kys3. Like I said above, it seems to vary quite a bit from case to case. I've actually seen more issues with the southbend clutches than I have with the kys3. It's really just a crap shoot in the end.
