New 2008 cobalt BOV?
Is this turbo loud is it able to take an aftermarket BOV? im assuming its the same turbo as on the hhr ss if anyone has videos or input thank you
Hmm no one has a TC yet haha so no vids... there's a few posted from testing and what not, it's not that loud.
Originally Posted by Acey
(Post 2316948)
It's something to do with the bypass air is fed back into the intake or something as to not waste the air, I don't know exactly how it works, but it won't be as loud as the typical blowoff you currently hear on the street.
why does everyone talk about blow off valves all the time? they really aren't that cool, i had an atmospheric greddy type r on my mr2 turbo and the noise gets really annoying and the novelty wears off after about a week.
i believe the LNF doesn't have a BOV, it has a recirculating bypass valve? i stand to be corrected but i'm pretty sure. |
with the no lift shift it be pointless anyways you dont wanna lose the pressure
Sorry i did not see the other threads im just trying to find out cause i know this turbo system is different deal as other cars so im trying to see what my options are
I'ts a bypass valve, bov is pointless since you want to maintain your boost not release it, why would you want one? Personally, I hate the constant spooling, esp when your in traffic where its sorta moving then not, you hear it spool constantly and I wanted to shoot myself in my friends car every time he went from 0-30 to keep up with traffic.
Originally Posted by RForte1189
(Post 2317006)
a blow off valve is used for bad situations such as HIGH Speeds about 100-200mph.... also for a turbo running ALOT of boost which the stock SS/TC will not be doing.... but hey if you want to tune it to 20psi then by all means get a blow off valve
let it stay quite man... ppl who race u will be like oh its ure basic cobalt... and then wen u f-in burn them they will be like, "omg did you turbo that?" Its a sleeper man... Wake it up by racing but if you get a BIGGER turbo... or too much pressure from a high tune boost then definately get a BOV |
Originally Posted by PimpLay2
(Post 2329067)
Originally Posted by D4u2s0t
(Post 2329073)
it may hit close to 20 psi stock.
unless constantly ure turbo feels that it has to boost at 15psi or higher then yea get a bov so your turbo doesnt wear out but if it feels the need to boost higher then let it.... its doing it for a reason by letting away pressure with a BOV ure basically saying hey boost stopppppp!!!!! |
It makes sense to want something that makes you faster. It's just plain stupid to want something that makes you slower. An atmospheric BOV will do two things: 1) screw up your AFR because you are blowing off metered air and 2) throw all your boost pressure out the window instead of helping keep the turbo spooled.
But hey, being cool trumps being fast right? Just look at all the fart can sticker racers. |
its a return style system anyways, which really proves no aid towards creating boost, but is realitivly better then blowing it off. again...upgrading the turbo would resault in a BOV. but as they sit stock, the return style system is better then putting a BOV on.
upgrading the turbo will not result in a BOV.
You need to really boost a huge turbo. And somebody who really does one hell of a tune. You know how hard its going to be to trick the ecu to think boost pressure is still re circulating and not blowing off. VERY! This car will no longer be available by the time somebody comes out with that much tuning solution |
i'm sure hahn will come out with a kit that will decimate all
Can anyone tell me what a BOV does??? Because it doesn't seem like anyone even knows... Maybe you guys should just stick to your superchargers. And there will probably never be a stock car that comes with a "Blow off valve"... Maybe a "bypass valve"...
P.S. Someone said that a "BOV" was only used for bad situations such as HIGH Speeds about 100-200mph... Hate to tell you but that is a big load of BS!!! The "BOV" or "bypass valve" is used to release pressure in the piping after the throttle blade is closed and vaccum is present. Thats when it opens. It keeps the turbo from back spooling (something a supercharger will never encounter). And it also keeps the turbo spooled between shifts better because it will allow it to somewhat free spin keeping the rpms up. So yes... even though it will have the "no lift shift" there will still most likely be a bypass valve for turbo longievity.... |
Originally Posted by Toobaditsaford
(Post 2416151)
Stay on topic, don't post unless you are furthering the thread topic. Childish or pointless comments are unnecessary, if you're making a point explain it with facts and information.
(Post 2416174)
wow...you know what a BOV does. congrats. we have known for a long time that the SS/TC's have bypass valves, as do our supercharged engines. so calm down turbo fanboy. the bypass valves throw the air back into the intake tube. it is audible iin the SS/TC and will only get louder with an aftermarket intake.
Thank you. Seems your the only one who read my post at all. And also, my post was not childish nor off topic. I was just stating that the BOV or BPV was used on all turboed applications... not for high speeds. So thank you xonic for helping me out there. And it seems that people think having the bypass valve go to the intake keeps boost up. Sorry but no. It simply releases pressure, doesn't store it.
Originally Posted by xonic
(Post 2416275)
It's pretty obvious that many other people in the thread don't. I wonder how much boost the BPV will hold. Some guys in srtland have issues with the stock one leaking at higher boost.
(Post 2416453)
(Post 2416453)
Yes you are correct... The bypass valve will work great. And I was talking more about the bypass and bov as a whole. Just didn't seem that everyone knew what they really did. You can get aftermarket bypass valves too to hold more boost and not mess with the metered air. I'm a big ford guy but my girlfriend is crazy about these cars. I stumbled across this thread and just had to help out. I have an 81 mustang with a boosted carburated 4cyl on 17lbs of boost. All custom built by me. Sorry to come on so strong and seem like a total a**.
And thank you for clearing that up REIGN SS. |
(Post 2416582)
