Oil flow troubleshoot
Old Dec 11, 2018 | 05:55 PM
Balento18's Avatar
Arrow Oil flow troubleshoot
Hello guys!
I am in need of a oil flow diagram so I can diagnose a noise that I have coming from the head that only comes up at 1,100 rpm and my spark advance goes to 15 . This engine was built recently after a it failed due to knock. I also installed a new turbo so my tune is not optimal.
Old Dec 11, 2018 | 08:08 PM
tomj77's Avatar
whats the noise?
Old Dec 11, 2018 | 10:21 PM
Balento18's Avatar
it sounds like the lash adjusters are bad but we want to be sure before buying new ones. A little back story: My engine had a bearing failure so I purchased another engine that had a broken piston and fixed that one. The fist few turn ons gave a sound from the head that went away once the engine stabilized, our theory was that the lash adjusters where not loading oil into them fast, if you wanted to avoid the loud sound at start up, you would have to turn the ignition off while stating (and repeat that) so the lash adjusters would charge oil. After a few oil changes the sound went away when cold start but we can hear noise when I give it a little bit of fuel (1,100 rpm) I hear the noise. I have an RPD unit and I also notice that the spark advance goes to 15 when I do that but no sure if related.
Old Dec 12, 2018 | 08:40 PM
tomj77's Avatar
well pull the valve cover and have a look. you should see if anything is bad.
Old Dec 13, 2018 | 12:26 AM
user 72239's Avatar
Originally Posted by RBruckner
So the oil pump feeds the Valve cover while simultaneously feeding the turbo. The friction caused by the oil moving at 60 psi @ 60c can speed up the heat. Sometimes you get low oil pressure due to this, which causes your transmission to not engage correctly
What in the ****?
Old Dec 13, 2018 | 03:52 AM
Balento18's Avatar
I think this may apply for an automatic transmission, mine is a 5 speed manual.
Old Dec 13, 2018 | 08:44 AM
steelmesh's Avatar
Originally Posted by Balento18
Hello guys!
I have the diagram on another computer, I think it was from an HHR forum; it took a while to track it down via googling.
From memory: Oil Pickup > Oil Pump > Oil Filter > Mains/Rods/Balance/Squirters > Orifice > Lifters
The orifice is inside the head and the pressure bypass is on the front cover.
Old Dec 13, 2018 | 09:20 AM
exninja's Avatar
What in the ****?
Just ignore this, it's someone being silly.
rcarr0327
Jan 4, 2013 03:02 PM
Ltguy
Aug 4, 2012 04:18 PM
Josuizzle16
Jun 16, 2012 06:04 PM
xxxxsh4d0wxxxx
Sep 19, 2008 05:12 PM
455rocket
Oct 15, 2006 11:50 AM
