Opel Injectors or Nah
Alright guys so my car is fully bolted and needing a retune. I have a 2009 so my injector seals are not e85 friendly. I go to school down in the city where e85 is everywhere. Im thinking about getting the Opel Injectors before my retune and running some E this summer. Is that a bad idea or no? I think I should be okay but would like more input. My head is stock 100%. Also ZZP will be tuning my car on their dyno.
Also, what kinda numbers are you guys pushing on a 24-25 psi e85 tune ? Thanks
Damn, this little ni.gga still around? How's college? You doing good? You actually man up, mature or you still clubbing and being the high school honey glazed ass troll you were?
Hahaha I never went anywhere and yeah I operate and set up CNC here at a family owned tool making shop 55 hours a week and go to specs howard for digital media arts . I might still troll a lil
Unless you plan on upgrading your intake cam with a larger hpfp lobe, and/or plan on going with a larger turbo with e47, I really don't see the need for the larger injectors. Also consider this. If you just slap on larger/higher flowing injectors into the system, you're now exploiting the primary weakness in the system to begin with. Which is the hpfp no longer keeping up with volume demands and rail pressure tanking even worse than it would to begin with now that the injectors flowing more, which now results in ever larger injector pulse widths that now starts trickling down to further issues and ultimately leaning out. If you plan on doing all of this, I say then go for it. Otherwise don't even bother.
I also have an 09 (clearly judging by my name.. lol) and I've been running an ethanol blend in one form or another for over 3 years no and never once have had an injector seal issue. Is it POSSIBLE that your engine came with the incorrect seals? Sure. You however won't know until you, A) pull the injectors to check, or B) run ethanol and find out when they fail. Granted the ladder isn't the best option BUT, point is, you likely won't need the larger injectors and if you do, plan on shelling out quite a few more bucks to back the weakest point in the high pressure system to begin with. The hpfp.
Man I wonder if its even worth it then. Term said my rail pressure was dropping really badly on my new engine and I was wondering if maybe just a fuel lobe cam and some opel injectors would bring it back to life again. I mean it pulls fine but it isnt the " same " he said the new setup flows more air so needs more fuel and thats what I am basing this all off of. currently running an E blend ratio .
I would like some peoples opinions of tuners as of lately I just emailed terminator and he sold his HPT cable
So who is reasonable and trustworthy to upload a GMS1 tune copy the tables over and do a remap etc?
Sucks term used to hook me up.
Ryan I was making 359whp running e85 (@26psi) and stock turbo and Term said I was "pretty close" to maxing out the fuel system at that time.
At our altitude we can get away with a little less fuel of course, I'm sure that setup at sea level would have had issues...
Yes it sucks that he no longer tunes, he was the only guy I trusted with my car. If you find someone else let me know
When he told me he sold the cable my heart sank. We got love for ya term
Not a hard on just tuner love.
Terminator said I could benefit from some fuel cams my new block/head flows that well. Might as well get fueling checked out and nailed out before carrying on. Sending this core to be built in 2 weeks.
Sure, but I still don't see the point in it. I made 350whp stock turbo with e47 on completely stock fuel system with zero issues. There is absolutely no hp gain to be had with going to these injectors on the stock turbo plain and simple. Is there a benefit to having them? Sure, if you're running straight e85 and/or upgrading the turbo. Even then, you would still need the supporting mods to supply the higher demands of the fuel and injector size. Just my .02
Well I just ordered GM stage 1 sensors, fuel cam , new trans , clutch, opel injectors.
