Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LNF Performance Tech (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/)
-   -   p0101 - need help (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/p0101-need-help-283914/)
slobalt22 Aug 2, 2012 12:20 PM
p0101 - need help
Car is throwing that code, so I replaced the mad sensor but it didn't help. Car was running fine then it started just boosting to 7 psi, thought it was limp mode but I've restarted the car, and unhooked the battery, still nothing. My intake sounds completely different then it usually does, no loose couplers that I can find anywhere. I found a spot on my intercooler where it could of been leaking and patched it with jb weld, still no fix. Any suggestions?
maf, damn autocorrect
getwicked Aug 2, 2012 12:24 PM
Spray all of your piping and intercooler with water mixed with baby shampoo or hand soap. That'll find a leak. If no leaks, start ohm testing the wires coming from the MAF.
SSlobalt Aug 2, 2012 12:52 PM
Um...............replace your intercooler with a metal one. ZZP is out until Sept or so, so go with the Treadstone one.
victoryredturbalt Aug 2, 2012 01:11 PM
boost leak
slobalt22 Aug 3, 2012 06:08 PM
yea found it, plastic end tank on the passenger side of my intercooler is cracked wide open....
victoryredturbalt Aug 3, 2012 10:47 PM
looking at ur sig, seems ur ready for an upgrade any way :D
Also I recently replaced my IC. I went with MPx's. It fits great......take a peak, heres trhe link
Intercoolers & Pressure Piping - MPx Intercooler 08-10 Cobalt SS Turbo
