P0234 Help!
Haven't changed anything on the car in a long time, went wot and noticed boost spiked to 30 and held there, shortly after got a p0234 code for over boosting. Can anyone please help and direct me in the right direction to get this fixed. Thanks
Any help?
Well you are going to set that overboost CEL at that psi obviously.
Is it repeatable? |
Originally Posted by umrdyldo
(Post 7238564)
Is it repeatable? |
Any ideas? really would appreciate some help. Thanks
Maybe something happened to ur wastegate, nut moved or something
Originally Posted by tomj77
(Post 7241324)
Originally Posted by 007 redline
(Post 7241538)
Went to a local dealer and they said its an internal issue with the turbo, what do you guys think?
(Post 7242176)
Possible, but not necessarily the fix. Are you still under warranty?
just got codes P0011 and P0010 which are sensors that need to be changed, is it possible these bad sensors are causing code P0234?
(Post 7242424)
Easy change too |
I had an issue a while back with the wastegate solenoid sticking due to oil getting blown in there and gunking it up. Perhaps you have something similar going on and you may need to spray some MAF cleaner through it to clean it out.
I just changed the Evap solenoid and now every time i turn my car on I get p0010 after I clear it. Before changing the Evap I would get the code maybe once a week. I'm changing the camshaft position sensors tomorrow hoping it'll fix everything.
P0010 is for the camshaft position actuators. Change them
(Post 7253308)
(Post 7253593)
I am when I get home today, my question is would the sensors being bad cause my overboosting issue?
What mileage are you at? |
(Post 7253602)
Not likely, they are a common failure point. What mileage are you at? |
thanks guys, it looks like an easy fix, im still puzzled about the over boosting issue. im not getting any other codes besides the p0010 now
(Post 7253619)
Originally Posted by tuned08ss
(Post 7253623)
Did it spike to 30 just that one time?
