Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LNF Performance Tech (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/)
-   -   P2261 issues (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/p2261-issues-318852/)
SPOOLING Aug 23, 2015 10:53 PM
P2261 issues
So to keep it short I was getting the P2261 CEL. Had some turbo flutter and decided to change the BPV. Bought a Forge and installed it and I'm having the same issues.
It's installed correctly with the opening down, green spring. I'm still getting turbo flutter up until about 3k or so..after that it doesn't even blow off? Unless its just that quite...
I took it apart and it's fully lubed. I can also boost past 5LBS. I'm also still getting the p2261 CEL.
Thoughts, suggestions?
SPOOLING Aug 26, 2015 02:25 PM
So I took it for a ride today. At low boost I get turbo flutter but not at high boost. High boost its fine.
Should I try the yellow spring maybe? It seems most people have had issues though and stayed with the green.
umrdyldo Aug 26, 2015 03:40 PM
First thing to try is deleting the vacuum tank
PI: LNF- Intermittent DTC P2261 - Cobalt SS Network
Sl0wbaltSS Aug 27, 2015 02:19 AM
First thing, do the vaccum tank delete mod. Then be happy and do it the easy way.
Are you tuned at all?
SPOOLING Aug 27, 2015 02:53 AM
Yes Term2 tuned. Should I still try the tank delete mod? Is there any pics of the mod around?
Sl0wbaltSS Aug 27, 2015 10:50 AM
Yep do it.
https://www.cobaltss.net/forums/08-1...esting-315220/
So basically, take the line coming from your BPV and plug it in directly into the intake manifold nipple at the top and unplug the line that the little boost solenoid thing from the manifold, then unplug the line from the vacuum tank to the little boost solenoid thing and unplug the bottom one then get some vacuum live from the parts store and cover up the 2 loft over holes on the boost solenoid thing with the same piece of vacuum line.
Then you're done!
I had fluttering problems at wot and if I let off before 6k, now I don't have any!
SPOOLING Aug 27, 2015 01:52 PM
so basically just get about 6" of line and do this with the lines....
[IMG]http://img.photobucket.com/albums/v6...psx5tzierb.jpg[/IMG]
LNFwagonSS Aug 27, 2015 10:29 PM
Or you could attempt to actually diagnose the problem if you have the tools. Use a mityvac vacuum bleeder or similar and apply 10-15 in.hg vaccum to each side of the tank to see if it holds. One of the hoses will be used to see if check valve still works and the other side is to determine if tank is intact and not cracked( you will need to plug opposite hose during this test).
Sl0wbaltSS Aug 27, 2015 11:42 PM
If he's tuned anything above Factory, GMS1, or a HPtuned factory tune or a HPtuned GMS1 tune you ARE going to have BPV issues. Just do the vacuum tank delete and it's fixed and the BPV opens all the way.
Also sp00ling that's my pic :lol: I'm css net famous!
LNFwagonSS Aug 28, 2015 07:35 PM
Weird, I've been tuned with trifecta and HPT without any BPV issues.
reybalt Aug 30, 2015 06:32 PM
P2261 issues
I have the same problem but my car is running lean too.
