Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LNF Performance Tech (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/)
-   -   Problems with car!! (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/problems-car-262057/)
ssballin Sep 27, 2011 02:22 PM
Problems with car!!
if the dealership replaced my timing chain then i started throwing a code(p0011)..is that a problem caused by the dealership or did it just cause my timing from my tune to be off, and i just need a reflash?
Team SS Sep 27, 2011 07:20 PM
P0011
This code will trigger the check engine light under the following condition:
The comprehensive component monitor, referred to as the CCM, monitors the Variable Camshaft Timing (VCT) position for over-advanced cam timing. If the cam timing exceeds a maximum calibrated limit or is stuck in an advanced position, the check engine light will come on and set this trouble code.
Possible Causes:
Incorrect camshaft timing
VCT solenoid valve stuck open or continuous oil flow to piston chamber
Camshaft advance mechanism binding, or faulty VCT unit
ssballin Sep 28, 2011 12:12 AM
right but do u think this is a dealership problem or do i need to be retuned cause the dealership isnt gunna match the timing that i had on my tune?
Team SS Sep 28, 2011 10:54 AM
Was the BYT tune in at the time of the service work? or was it tuned back stock before the work was done?
nitroinsane Sep 30, 2011 09:30 AM
Ignition timing and camshaft timing are not the same
Chevycobaltss3 Sep 30, 2011 09:42 AM
this happeneed to one of my customers. His issue was the car jumped a tooth (Car wont go in to any vvti like this) So go back to the dealer!!
BlueTurbo Sep 30, 2011 10:14 AM
Either they did not install the timing chain correctly (surprisingly easy to do) or you have a faulty intake camshaft actuator or solenoid. The solenoids go bad all the time, the internal resistance gets too high and they read incorrectly. I can guarantee this has nothing to do with your tune. The tune doesn't effect cam timing...
nitroinsane Oct 1, 2011 07:46 AM
But pull the tune out fyi
