Racoon causes Varying Turbo Boost Levels
Also, can you change the intercooler and charge pipes with a GM1 tune in the car or will it throw the fuel ratio's out of whack ? If you go to charge pipes with better flow I thought you had to have a tune that you could adjust to the upgrades ?
Sorry, old dog just learning about the turbo / computer / tune world.
It keeps temps in check which you know is more than likely the cause of that knock, assuming the IAT2s came down, and we know hotter air means less power, so its kinda a performance gain.
My tune is old I ran it in the summer ZZP intercooler no knock. I turned down the boost 2psi and timing down and still had 4* or knock I believe the flow is so terrible that it may have got a lot of extra heat. Let me go check my log to see where my IAT2s are
I just checked my IAT2 were at 55* because this happened just a bit ago and it's getting cold here. I added liming and lowered boost and all my knock went away. The stock intercooler just didn't like my 26psi tune. but all my knock was in the mid range through the whole rpm load chart. My meth fixed it up top
I'll have to double check my log tomorrow but I only added timing up top for meth so I'm guessing stg1 level. But it had the exact same fuel in previous with less timing and less boost than my run with the zzp intercooler
#36
Any opinions on why this issue of boost and no boost would be so intermittent ? I can go for a 15 minute drive and one moment there's no boost, then some boost and then none again.
Is the computer maybe doing something with opening the waste gate or something ??
Thanks.
Thanks.
#40
Thanks.
Thanks.
#43
Thanks.
Thanks.
1.find leak
2.fix leak
3.????
4.profit
#44
#46
Hot side pipe coming off turbo to intercooler
https://www.cobaltss.net/forums/how-...ss-lnf-223319/
I saw a cap mentioned and saw someone said they didn't need to cap it.
Thanks.
