Random misfire
I'm not trying to say what it is. It could be a valve problem... could be a lot of things.
But I had from passenger side: 146, 126, 138, 30
NEW pictures of OLD pistons... so there's some rust.
What my 126 piston looked like
What my 30 piston looked like
You'll have to do some digging.
Sounds like #4 **** the bed. Keep us posted. Only chance you have is to go back to stock & write entire the stock tune if it isn't. Even then there are signs you were tuned in the BCM/ECM data & history. They can tell you just flashed or reset the ECU as none of the emission tests will show ready.
GM is currently requiring a deep drilldown into the ECU on many 'tuner' cars like the LNF on an engine failure.
If you log all 4 cyl misfires in HP Tuners, you will see the misfiring cyl count go up like crazy on the dead one at idle when the CEL flashes. Sometimes #2 will show as #4 and #1 will show as #3 but you will see the most dominant one.
When mine went, it also ran a little funny at idle about 1-2 weeks prior to it just giving out. First I started killing it while leaving from a stop. I thought that was rather unusual at the time. Looking back it now makes sense that it was low on compression for a few weeks before and just didn't have much off idle or low rpm torque. It seemed to run fine otherwise and no codes set which is why I didn't pay much attention.
Good luck! I hope they warranty it for you.
#36
I have everything to go back to stock, and since my friend has an HHR SS I got lucky that he still has his stock IC which I'll be borrowing, since mine came with the aftermarket one.
#38
Well got a call from chevy, the cylinder head needs to be replaced(kinda was hoping I would be getting a new engine haha), its getting covered under the powertrain....now just to get them to let my rental be a corvette
Sean Cummings
03-09-2018 12:26 AM
Getaway_Driver
09-08-2015 09:41 AM
