Spark Plug Socket Stuck in hole. With Pictures
So my engine had got some water in it due to me hitting a puddle in a bad storm in August. So, I finally had some time to try spinning the engine after taking the spark plugs. Before I could even get started, I guess I was paying attention, I put (lords knows what size) a socket down there and tried to lossing the plug...well the plug broke off and the socket got stuck. My father told me to torque it (Which I know better but he's my father) once i did it...it became stuck for real! Now I need any advice on how to get it off,
https://cimg8.ibsrv.net/gimg/www.cob...1419e68c42.jpg thanks! https://cimg9.ibsrv.net/gimg/www.cob...deb65a316f.jpg So i figure out some of the pieces got stuck in between the socket and the bot. This is probably why its stuck in there good! |
That's a new one.
Can you get some needle-nose pliers and rock it back and forth? If you manage to get the socket out, be sure to get every bit of glass out of there before you take the plug out. Last thing you want is glass in your combustion chamber. Although if you hydrolocked you've prob hosed the engine regardless. |
No luck on that unless I need bigger needle nose but once I start pull the needle-nose just slide from it
An angry stupid mechanic would put an impact on that thing and hold the trigger till the fucker comes out
Personally I don't know what I would do. I would probably try to put a ratchet on it and go clockwise and counter clockwise untill it moves up or down some. But yeah that sparkplug is fugged up in there. Worst thing would be having to pull the head to get it out. Might try some lube in there too. |
Originally Posted by umrdyldo
(Post 7626416)
Also, go get a spark plug socket. They are made to prevent this from happening. Unless by some miracle your compression numbers come back good, you're pulling the head off eventually. If you bugger the spark plug threads you can still use a heli-coil so your head is not doomed because of this. |
You need a slide hammer and a little hook to get into the opening.
Originally Posted by ECaulk
(Post 7626423)
plz use a spark plug socket next time. |
Originally Posted by ThoR294
(Post 7626513)
this will work.
How did u break the plug to begin with? Did u turn it the wrong way? I agree with the slide hammer idea.
ok so i realize this tread is old but i know this happens often so here is a little tip for you all have this issue. there are tools called "locking extenstions" its an extenstion with a locking tip, once the extension is in the socket, it locks to it and wont come apart till you unlock them... also ALWAYS spray a little rust penetrant in the spark plug holes and let it sit before you wanna try taking the plugs out and NEVER try to pull out plugs from a warm aluminum cylinder head. hope this helps
Always use antiseize
Originally Posted by tomj77
(Post 7631807)
Some say it changes the applied torque and can lead to over or under torque. My last set of plugs had 50k miles and were partially rusty on the threads. Not cool. |
I've always used anti-seize on spark plugs.
Originally Posted by exninja
(Post 7631813)
I've never used anti-seize on plugs and never had an issue taking them out. I guess its a LNF thing?
I've never used it either and changed the plugs in my car several times
Just slap some red loctite on there ;)
If I were to use antisieze it would be the slightest amount. Torque spark plugs to specified torque and you shouldnt have a problem. And remember, extensions do effect torque specs. |
Originally Posted by no_ss
(Post 7632125)
Just slap some red loctite on there ;) If I were to use antisieze it would be the slightest amount. Torque spark plugs to specified torque and you shouldnt have a problem. And remember, extensions do effect torque specs.
Haha I think that was sarcasm with the red ;)
Yup :lol:
https://cimg6.ibsrv.net/gimg/www.cob...359e1f00a0.jpg
All kidding aside, I use copper anti-seize. I find the silver stuff tends to dry out over time and get gummy, the copper does not. |
