Stock Turbo PSI??????
Just trying to fiqure out what the bone stock PSI is on the Cobalt SS/TC Turbo. Please Help cant find.
Thanks in advance
Thanks in advance
Not true. First off the boost wont be the same all the time. On a hot day 15-17 is normal and on cold days, like sub 80*, I can see 13 psi. The car adjusts accordingly
normally mine hangs around 15 below 75, seems to creep up to 17.8 as you get to 92 or so and then goes back to 15 over 95ish, at 6000ft altitude i see 17.8 and i've seen 13.2 when it was in the 40's
so it boosts higher in the heat?
Im guessing when you punch it, the highest number the gauge goes to is what you guys are talking about, correct?
sorry, im new to turbos....lol
The highest number it hits on the boost gauge would be what it spikes to then whatever it falls down to is the regular boost. Most likely will be around 15 psi on a stock tune.
