Thoughts On All Intakes Currently Avaliable For the SS/TC
Old 03-27-2014, 12:23 PM
  #401
FutureEcotecOwner's Avatar
Ok I will look and try that
Old 04-03-2014, 10:34 PM
  #402
bspeed's Avatar
cant wait for my k&n to come, whats the reason behind turning the cone filter to 12o clock?
Old 04-10-2014, 11:51 AM
  #403
tuned08ss's Avatar
So if I currently have a dejon sri and am tuned for it, if I want to go with a k&n sri do I need another tune? Or will it be ok with the tune from the dejon intake.
Old 04-10-2014, 11:53 AM
  #404
umrdyldo's Avatar
It changes the fuel trims closer to 0 than other positions.
Old 04-10-2014, 12:48 PM
  #405
northvibe's Avatar
You could also try doggy style or cowgirl....
Old 05-03-2014, 01:13 PM
  #406
tuned08ss's Avatar
Once again before I do what u all hate and make a new thread.
I have a dejon sri and I want to switch to k&n. Will this affect my fuel trims at all? I am tuned for my dejon but if I switch to k&n will I still throw a cel. I can monitor some things with my interceptor but I just want to know if I anyone else swapped intakes and had problems.
Old 05-06-2014, 09:59 AM
  #407
tuned08ss's Avatar
^Bump for answer to above question^
Old 05-06-2014, 10:03 AM
  #408
umrdyldo's Avatar
You probably won't need a retune unless the Dejon was way off originally.
You can adjust fuel trims a bit with the K&N by rotating the filter.
It will change your fuel trims, but probably not enough to throw a CEL.
Old 05-06-2014, 10:24 AM
  #409
tuned08ss's Avatar
Ok thanks...everyone keep an eye out for my dejon for sale soon
Old 05-28-2014, 12:54 PM
  #410
tuned08ss's Avatar
Quick question. Does anyone know if the filter from a k&n intake will fit the dejon sri piping? Are they the same diameter?
Old 05-29-2014, 12:29 PM
  #411
Terminator2's Avatar
No. The Dejon is 3" the K&N is 3.25".
Old 06-13-2014, 10:41 AM
  #412
AARON-SS-TC's Avatar
^ This, I have the metal pleat on mine positioned at around 11 / 12 o'clock.
****, I THINK MINE IS AT THE 3 O'CLOCK SETTING. IT JUST LOOKED LIKE THATS WERE IT NEEDED TO BE DUE TO THE SHAPE OF THE FILTER.
Old 06-13-2014, 10:53 AM
  #413
Turn your caps lock off I feel like you're screaming at everyone
Old 01-19-2015, 01:20 AM
  #414
09RallyTC's Avatar
Is there an intake for the relocated MAF? I have the stock air box with K&N filter. I will be getting a tune afterwards.
Old 01-19-2015, 08:52 AM
  #415
blueLNFftw's Avatar
Just the cover for the MAF hole.
You need a tune prior to doing it. If you relocate it and try to start your car you are going to have a bad time without a base tune for MAF relocate.
Old 02-19-2015, 11:46 PM
  #416
Gugi96's Avatar
it says the Hahn cool ram intake gives 30 hp but how much does torque does it give?
Old 06-08-2017, 08:27 PM
  #417
tomj77's Avatar
Lol don't beleive that bs
Old 06-08-2017, 08:29 PM
  #418
tomj77's Avatar
I'm on the zzp turbo upgrade intake, 3.5 inch on s257. Had too mod it for oil separator and pcv hose , but I love it. Huge filter, looks good. Turbo spool is freaking loud. Sounds like a supra big turbo is spoiling up when u ease into it
Old 06-08-2017, 09:32 PM
  #419
63 Nova SS's Avatar
I'm guessing in the 2 years since he posted that, that he may not have the car anymore. But yes you are correct.
Old 10-02-2017, 04:18 PM
  #420
05duramax's Avatar
So what are the thoughts on the ZZP intake?
Old 10-02-2017, 04:19 PM
  #421
user 72239's Avatar
after helping ecaulk put his on. its a piece of **** that wasn't well designed.
Old 10-02-2017, 04:32 PM
  #422
hawkssoccer11's Avatar
stay stock or go with the K&N SRI
Old 10-02-2017, 04:38 PM
  #423
I mean it was a cheaper intake, so I wasn't expecting a perfect fit, was certainly expecting a closer fit than it was though. It sounds nice and doesnt seem to limit airflow, haven't performed an UOA to know how well the filter works, but I assume it's just a branded K&N judging by the appearance
Old 10-02-2017, 04:39 PM
  #424
Oh and you def want a hydroshield or you will most certainly have rough starts after rain
  #425
05duramax's Avatar
I just bought a 2010 SS, the guy had put on a K&N Typhoon
Quick Reply: Thoughts On All Intakes Currently Avaliable For the SS/TC
