Originally Posted by Gestapo007
(Post 4745067)
i dont know if this has been discussed, but i thought of it yesterday and was curious. CIA's MAF relocation pipe for blow off valves.... if you relocate the MAF in this car, then any intake problems should be fixed. Wouldnt this seem correct. No more MAF's too close to air filters causing turbulance. Is there less turbulance after the intercooler? Anyone ever test one of these and look at MAF skew?
Actually now that I think of it they say you have to tune for that. so then whats the point as you can tune for an intake. |
Tagged for quick reference.
Nice write up Term |
Originally Posted by steddy2112
(Post 4745805)
No, I really don't
Term says every intake is headache unless you are meticulous about tuning for it. 15 whp to be had? I can live without it for now :lol: |
(Post 4746631)
No, I really don't
Term says every intake is headache unless you are meticulous about tuning for it. 15 whp to be had? I can live without it for now :lol: It's 15 whp. O.O I have comfort in knowing that I was looking into hahn and figured it costs as much as it does for a reason. At least I had a positive hunch on something |
(Post 4746631)
No, I really don't
(Post 4745805)
Nice write up Term
Originally Posted by G85 SS
(Post 4746636)
But sir...
It's 15 whp. O.O I have comfort in knowing that I was looking into hahn and figured it costs as much as it does for a reason. At least I had a positive hunch on something http://img192.imageshack.us/img192/7...eicdpcpscb.jpg That was with a PPC tuner which uses the stock MAF tables and stock timing so more of a conservative tune if you will. |
I pulled a 4.7 with 100% stock parts, then 4.4 with DP, CP and K&N, 4.07 with Hahn CAI on the car.
Originally Posted by BYT*SS*TURBO
(Post 4746940)
Im also on my snow tires, after changing my wheels yesterday I realized they are quite a bit heavier! I plan on throwing a 24psi tune on it then running him again. Should put some space on him, not a ton but a lil bit :)
(Post 4747076)
Cmiller had that Highboost kit inline like the pill mod shows. It was making his boost come on really slow, he thought it was the TF tune possibly, he said it never came on right and just thought it was the tune. (I never even saw a 24psi spike in his log he sent me with the TF tune on the car) After I sent him a file to try, it did the samething. We came to the conclusion that it has to be something with the Highboost kit and he tried pulling that Highboost kit out. His car now boosts right and that's really where he gained his time.
What I think those races showed is exactly what you've been saying. The AF really does make a difference. I was running less boost rolling off boost sooner and pulled the same with less boost and the right AFR. Im betting that with 24psi Ill put a car on him, the car def pulls harder thru the midrange with the pill in and that's where he gained on me everytime. I find it strange you aren't pulling faster then me with 40 extra whp lol. Somehow our "dense air" makes the car go faster yet doesn't make that 40whp jump you have on everyone... where's that dyno btw? ;) lol! |
Yea, that highboost kit was hit or miss, I took it out and all is better. The boost would come on real slow sometimes and others it would spike real big and settle down. I am looking to prolly do the pill mod to soon and get it dialed in for the track in a month.
(Post 4747133)
(Post 4747272)
I should do some data logging with the dashhawk so we can get some solid numbers recorded and make this thread even better...what you think term2? I have a stock intake and a drop in k&n I can record for.
Originally Posted by Terminator2
(Post 4747279)
Different dyno. Why are you so hung up on the numbers? My car made 253 whp stock on that dyno which is about 5% more than most make stock. 340 X 1.05 = 360 hp. You dynoed 320 whp with the crappy stock airbox on the car. An Intake adds up to 25-30 whp up top. You should make 345 whp or so on that same dyno next time with the intake and the pill. Stock airbox vs intake is no comparison as far as top end hp is concerned.
You must be one helluva driver to pull off those QM runs that fast considering where you were tune wise before. Get yourself a Hahn intake and a pill and some retuning and you should be hitting 11.6-11.7 at 116-117 mph. :twothumbs And Im hung up on numbers? You brought up numbers with my 60-100 times yet you ignore my question about how my dense air could make my car faster yet I dont come close in whp to you? Any thoughts on that one? And I agree on the Cmiller front. We're throwing a 24-25psi tune on it now and 11.7-11.8 def seems attainable! |
You must be one helluva driver to pull off those QM runs that fast considering where you were tune wise before. Get yourself a Hahn intake and a pill and some retuning and you should be hitting 11.6-11.7 at 116-117 mph. :twothumbs[/QUOTE]
It didnt always act like that. It was better for awhile and I never had the highboost kit on there. If I didnt spend so much money on the things I just bought I would get the hahn intake. What would it do if you left the filter out lol. |
Intake/ gms1
Hey, not sure if this is the right thread for this question, but regardless there always seems to be good feedback from some knowledgeable people wherever the posts go... I am about to do the GMS1 and have also ordered a new CAI. Am I better off putting the intake on before or after the GMS1 install? The reason I ask is for the purpose of the tune that GM performs on initial install. Or will the ECU automatically adjust as it learns the new intake, no matter when it's installed? Thanks for any help!
(Post 4747433)
345 is still not 360+ And as stated previously, I wouldnt be so hung up on numbers if it was within an acceptable margin. Not to mention now it says 24psi is teh latest tune when Blueberry dyno'd your tune at 22 to get those numbers you are claiming. End the debate, post the graph already ;)
Originally Posted by tomgillotti
(Post 4747858)
Damn, well there goes $300 until the warranty runs out... oops
Whoever HP Tunes your car can do a write entire back to the car with the GMS1 alone if you have to goto the dealer.
(Post 4748346)
^^^ Hows the clutch and flywheel working?
(Post 4735986)
In my opinion the perfect intake for the LNF would have a 3.25" intake tube made of Aluminum or Steel. It would have a separate MAF housing piece with a screen right in Front of the MAF to keep airflow readings consistant. The MAF housing's ID should be as close to the ID of the stock intake as possible to keep the fuel trims as close to stock as possible.
