Ticking under boost!!
So i was on my way home from school and got on it a little and noticed a ticking noise that sounds like its the turbo, but the car still boosts fine up to 22psi. Car still has crazy power. Coolant is fine. Wasnt using the heater so i dont think it was the fan. Its about 60 degrees outside. Just filled up today so could it be the fuel? An exhaust or gasket leak? I really hope its not the damn turbo because i just got the motor replaced last month due to the porus block. Any help would be great. Thanks.
bump need some help quick
it's the turbo, I had the same problem with the OEM TC, out of nowhere the TC just started to tick, found out later the bearings where packed with baked oil.. since your engine got replaced under warranty, you should go back to the dealership and tell them before it to late.
should i take my tune off?
i had the same problem with mine...turns out i just had a stud loose on my 02 housing causing a little exhaust leak
It's the rivet on the internal wastegate flap. See thread here: https://www.cobaltss.net/forums/2-0l...88/index2.html
This is apparently common with internal-wastegate turbos. Nothing to worry about. |
can i still run the car or should i let it set before i go to the dealer. my buddy wont be home til friday to take the tune off, is it going to be ok to drive or just dont risk it? also would my tune havve created this problem with the heat? Thanks guys this helps a lot
If it is the rivet, you're not going to have any issues. It's just noisy. Keep driving. Chances are, when you take it in, they're just going to roll their eyes at you, anyway.
With how noisy these LNF's are ....a video would really help..... just a suggestion. I would be paranoid too if the motor was just replaced lol.
you could fix it with a bigger turbo
Originally Posted by rukkee
(Post 6108439)
Originally Posted by Dart_SI
(Post 6108466)
I noticed mine making that noise after running it at 25psi on ehtanol. I thought it was the turbo hating me lol it is!
LOL at that link SSlobalt... Everyone got pissed at each other after they answered the question haha |
Originally Posted by RyRidesMotox
(Post 6108620)
have u put my tune on it yet and if u have wheres my log.
| All times are GMT -4. The time now is 10:06 AM. |
