top speed ecu will see
so discovered something interesting today, did a log late at night nothing on the road, so I decided to see what shes got. I pegged the gauge past 160mph it goes a little past them stops. then I looked at the log and according to the log it goes to 158mph and that's where it stops, the rpms keep climbing but the speed recoded in hptuners stops at 158 and will go no higher. is there some why to make the ecu register more speed or do I just need a gps if I want to see how fast it will go.
That surprises me since HP Tuners will allow you to raise the speed limiter to 318, I would think it would read beyond 158
Originally Posted by sc4door
(Post 7554324)
You could probably calculate basted on rpm. Not sure if that's accurate or not.
Does an rpd go over 158 if the speedometer does, but the ecu doesnt?
If the ecu can't see it the RPD won't be able to.
Originally Posted by slapbetcommissioner
(Post 7554556)
(Post 7554559)
I happen to know for a fact that the RPD does go over 158 :lol:
I'd try it out to see my results but I live in Ohio and there's no road straight enough to do that :lol:
I guess even if the ecu can't decode the speed signal past 158 doesn't mean the RPD isn't capable of continuing to figure it out.
(Post 7554559)
(Post 7554559)
Mine said 160 and gps said 152 |
Well I just top speed tested it, didn't burry needle like usual due to slight incline I guess. Speedo said 260kph, I guess that's same place on speedo as 160mph, hptuners says 158 mph, gps said 167.7mph or 270kmh, so this cars ecu definitely doesn't read past 158mph
(Post 7554677)
Scanner maximum speed tops out at 158 mph
The new 2.25 scanner can read past 158mph it's just a software limitation of 2.24 scanner. Built Corvette guys going 200mph+ on a dyno had the same complaint. |
Originally Posted by Jesse
(Post 7567629)
I got a flashing cel at 158 lol
Originally Posted by tomj77
(Post 7567639)
Oh sweet. And there is an update? Or will it be in coming update
So how did my RPD read 165? Does that mean my car came with the software upgrade?
It weird how the rpd works if I put mph on the interceptors and the rpd. The interceptors are off by like 1mph to the rpd
(Post 7567950)
Originally Posted by ECaulk
(Post 7567968)
The HPT software doesnt read about 158, not the car's ECU
(Post 7567973)
Ahh, OK. Wasn't that what HPT was reading that one time ;-)
(Post 7567950)
| All times are GMT -4. The time now is 01:54 AM. |
