Transmission Noise LNF GMPP
Alright guys, I'll try to explain my issue as best as I can.
Last year I bought a LSJ GMPP clutch for my LNF. I got it installed and the technician noticed that the holes around the pressure plate were a bit bigger than the holes around the flywheel (where the bolts go). He said a little bit of noise could appear. The flywheel was fine and did not need resurfacing. Its a 2010 Cobalt SS TC with 39K. A couple months after, I would say 3 months, I stared hearing a little rattling sound coming from the transmission. I noticed when going into a drive-thru, it echoed with the walls. It could have started before but I didnt notice it with the music playing etc. When I press the pedal clutch, the noise goes away. When I release it, it will sometime do it again, and sometimes stop until I press it again and let go. There is definitely something a bit loose in there but before I bring it to a mechanic, I would like to know what you think. I made some research and it could be the input shaft bearing or the throw-out bearing. It could also simply be the clutch not aligned 100%. Nothing changed performance wise and it shift smoothly as usual. Could the pressure plate holes of the GMPP clutch being a bit bigger than the flywheel holes be the culprit? It's not a grinding noise, but rather a regular "tic tic tic" coming from the tranny. Thanks for your help! |
The TOB bearing is going bad.
Drive it until it breaks. My car does this. The TOB has mere 5,000 miles on it. |
Yeah my TOB has about the same mileage. It sucks though since it's still almost new.
However I watched videos online and my sound is a regular tick tick that goes away when I press the clutch. Ive seen videos of bad TOBs and it sounds more like an irregular clunk. There is a debate between TOB failure and input shaft bearing failure. Any other insights? |
Yea. That it's the TOB. Like I Said; been there and driving it anyways.
I have an LSJ but I get the same noise. I wouldn't be too worried about it.
Alright thanks for the input guys. I'll just drive it until it's time to change my clutch again. Not worth spending another 6-8 hours of labor for that issue.
