Trunk mount meth kits
Let see some pics of Trunk mount meth kits
Going to install my AIS Stage 1 soon and would like to see some installs Going to try and fit under spare tire cover |
I have the first gen AIS kit mounted where the spare tire used to be in my 07.
If I feel ambitious, I will take a pic for you. Kevin |
i mounted my snow kit just to the right of the spare tire cover. did the plumbing today. went pretty good. will take pics sometime
Love your trunk setup, clean and hidden. Props to you!
my setup is not as pretty as his --^,but just as functional lol.
http://i1019.photobucket.com/albums/...n/CIMG1629.jpg http://i1019.photobucket.com/albums/...n/CIMG1630.jpg http://i1019.photobucket.com/albums/...n/CIMG1634.jpg |
Mine will also be the First Gen AIS Stage 1
Going to test fit it under spare tire cover today Did you make a mounting plate? I need to swap nozzles i think i got a 10 gph one AI10 it says Emailed AIS but didnt get an answer this week can i use any companies nozzle? Thinking 5 gph would be lots |
yeah 10 gph is too big, start with a 3gph the move to the 5gph if every thing checks out.
also what psi pump do you have, that makes a big difference?
Originally Posted by Gunney_07
(Post 5680091)
pump psi should be around 150psi
Originally Posted by cobaltsssc760
(Post 5680767)
i think this is the second post you said the same thing... but yes just as functional. i was gonna mount my tank in the spare tire but i had a cryo2 co2 tank that sat on the left side but it was thrown in the trash by a family member while i was on vacation.
also there is generally 3 psi settings. 150,220,250 and the gph rating on the nozzles changes when under different pressures. |
ha. i wouldnt get a pump over 150 depending what tubing your using to hook it up.
<tylerjclance> that setup doesnt stress your pump having to draw out of the tank straight up like that? |
my pump from Devils Owns is adjustable from 150-250, This vendor in particular only sells one type of nylon line that is rated for 350 psi operating, and 1400psi bursting.
Nylon Tubing Devilsown |
i jus have the tank mounted in the back and my pump is up front...and i have my pump up in the engine bay and it doesnt stress it out so i dont think his set up should either but who knows
Originally Posted by tylerjclance
(Post 5680099)
http://i653.photobucket.com/albums/u...e/IMG_2283.jpg
http://i653.photobucket.com/albums/u...e/IMG_2284.jpg http://i653.photobucket.com/albums/u...e/IMG_2282.jpg |
i never used my trunk so i just mounted it for ease of filling.
http://i281.photobucket.com/albums/k.../cobalt032.jpg http://i281.photobucket.com/albums/k.../cobalt034.jpg http://i281.photobucket.com/albums/k.../cobalt046.jpg activation light i had wired up. you can see it in this video skip to about 2:15 YouTube - 13.88@104 |
(Post 5684714)
See some of you guys have your meth pumps/tank mounted in the trunk, was it by choice or design?
choice
(Post 5684688)
the way the pump is drawing from the tank straight up like that cant be good for pump
I bought this AIS kit stage 1 with the 1.5 gal tank from someone never used apparently
What i got is 25 Feet of Tubing, Pump mounted to Tank, Switch with 3 electrical posts and one hose fitting and my Nozzle and 90 degree adapter Anyone have a good install instruction for such a kit? |
| All times are GMT -4. The time now is 04:54 AM. |
