AC delete belt
Old 09-20-2013, 03:34 PM
hucks1987's Avatar
AC delete belt
Does anyone what what part number or size belt is needed for a A/C delete?? Also is the ATI balancer the same side?
Old 10-16-2013, 12:54 PM
FasterIsBetter's Avatar
Idk if you can do an A/C delete without an idler pulley to take place of the compressor because the tensioner would cause the belt to come into contact with itself due to the compressor not being there. But the size for the underdrive ati turbo balancer is I believe 15mm smaller than factory. Or at least that's what I think mine was. It fit tight but after a couple times of putting it on and taking it off it got easier as the belt stretched.
Old 10-16-2013, 03:06 PM
northvibe's Avatar
I'd also be interested in this for future modding. I would suspect you could remove the AC compressor and put a blank holder w/ pulley. I haven't seen the belt diagram so idk if just removing that pulley part would make it rub.
How did the LSJ do it? I know they had the tune disable it, but did they do a new belt to "delete" it?
Old 10-16-2013, 03:36 PM
jrmotosports 88's Avatar
from what i have read so far we gut the compressor. i have been reading into this topic for a few weeks now. i am going to assume the lnf's are the same. my biggest question is do we need to disable the ac compressor clutch sensor in the tune? or will it be fine? very few threads about this topic, very few people have done this. i believe mark(exsoccer/DS) may know a bit in this topic.
Old 10-16-2013, 03:53 PM
AaronJ's Avatar
Unless you actually plan on removing the whole a/c system (compressor, condensor, evaporator, all the lines), I don't see what the benefit of this is.
Old 10-16-2013, 03:58 PM
in my case thats the plan, im never selling the car, i dont use ac, ac condenser must go and yes the extra weight loss wont hurt.
Old 10-16-2013, 05:47 PM
the ati balancer/super damper is on the same side
Old 10-16-2013, 05:53 PM
EXsoccer1921's Avatar
You mean like this?
Old 10-16-2013, 05:56 PM
thats pretty barebones huh! whats that a 1'-6" belt?
Old 10-16-2013, 06:00 PM
well you did go to the extreme. hahahahahahaha
is the easiest way to remove the ac out of a lsj/lnf, what is the best way mark? to gut the compressor? and do you need to revise the tune?
Old 10-16-2013, 06:08 PM
I mean I guess you could gut the compressor. But that pulley is still pretty resistant to spinning.
Old 10-16-2013, 06:37 PM
cmiller8006's Avatar
I also deleted the compressor, go to autozone, look up a non ac 07 cobalt or so and get it. That's how I did it.
Old 10-16-2013, 06:40 PM
They sold cobalts with no ac?
Old 10-16-2013, 07:13 PM
Yea
Old 10-16-2013, 07:19 PM
Grave's Avatar
4050345
That's what I'm using. (from Rockauto)
Old 10-16-2013, 08:01 PM
i assume that would be the best solution for a lnf
need more belt with a sc.
Old 10-16-2013, 08:12 PM
True
Old 10-16-2013, 08:24 PM
For me deleting the ac was just a byproduct of going with the ewp. I did much more than just get a shorter belt. But if you just want the ac gone then yes that would work.
Old 10-19-2013, 02:59 AM
GTOworshiper9's Avatar
Ecotec Belt w/o AC 24466976 12634322
Done.
Old 10-19-2013, 03:29 PM
iboost's Avatar
Subd
Old 08-19-2017, 04:07 PM
nutty21's Avatar
Sub'd
Supercharged06SS
12-11-2022 04:47 PM
DarrenGC
12-24-2021 01:55 PM
justinchinn
10-02-2015 12:18 PM
cw383
09-30-2015 12:41 AM
grampss
09-27-2015 08:51 PM
Quick Reply: AC delete belt
