Smoking issue
Smoking issue
So just fixed my timing chain and put a new down pipe and exhaust , its blowin **** ton of white whitish blue smoke wondering issues that would cause this and how i can test them also seems to have a small misfire
Whitish blue smoke indicates it is burning oil. I don't see how a timing chain replacement or down-pipe/exhaust could be the cause of an oil consumption issue. Is it possible your downpipe or exhaust had oil in it for some reason and what you see is that oil burning out of the exhaust system? Does it smoke all the time or just when you run the engine a certain way? I used to burn alarming amounts of oil and you couldn't even see smoke under normal operation though it would puff a cloud when I hammered down.
Miltb
05-02-2019 08:25 PM
