Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LNF Performance Tech (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/)
-   -   What is needed to run a Tial BOV? (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/what-needed-run-tial-bov-320789/)
TheReaper855 Feb 24, 2016 06:48 PM
Alright so looking to get the ZZP intercooler package on their website. I really would like to run a BOV on the my 09 cobalt ss tc (yes I know the stock wastegate blah blah) Can I just buy the kit with the adapter for the BOV and then buy the Tial BOV from ZZP? Do I need anything extra. I do know that you will need a tune for this mod.
Psykostevo Feb 24, 2016 06:55 PM
Tune for sure.
I still don't recommend running the BOV
TheReaper855 Feb 24, 2016 06:58 PM
Why may I ask? What makes the wastegate better?
SR Tech Feb 24, 2016 08:16 PM
You'll need the MAF relocate harness to move it into the lower pipe. And a tune obviously
tomj77 Feb 24, 2016 08:25 PM
hahaha wastegate.
u mean what makes the bypass valve better? the wastegate is to control boost on the turbo.
if u want to run a bov, you will have to get a lower chargepipe from zzp as well which would be in the intercooler package, and the maf relocate extension harness. then ur maf sensor goes into the lower charge pipe and u block off the old port on the intake with the block plate that u get with the charge pipe. then u will have to get someone to tune for the relocate. you maf needs a new tune. then and only then will it work right. also, ull probably want to run a lighter spring on that bov then they give you because the one they have in there is a little stiff, it allows for turbo flutter a bit still. ull need a spring light enough that the bov will probably be open at idle, which doesn't really matter, and if u still using the bpv solenoid for the bov, then it will stay closed at idle.
TheReaper855 Feb 24, 2016 08:38 PM
haha yes bypass valve. Pulled a blonde moment there lmfao! I think I'm still gonna go with the bov. It doesn't add anything power wise but you get to make turbo noises everywhere u go lol.
TheReaper855 Feb 24, 2016 08:39 PM
Plus would be getting a tune anyways once everything is on the car.
tomj77 Feb 24, 2016 09:42 PM
I ran bov and bpv when I was on the trifecta ecp tune. awful tune, but that sounded so fricken awesome
TheReaper855 Feb 24, 2016 09:44 PM
Ya will be getting a custom hpt tune
double clutch Feb 24, 2016 09:45 PM
Id love to have bov noises but ive heard of too many problems with it
Omiotek Feb 24, 2016 11:46 PM
you can buy zzps kit all you want. theres 2 ways to do this the right way.
Option a: use the search because this topic has been beaten to death here. theres more then enough threads talking about this..
but in all seriousness
option a: you recirculate. you need a tial qr. have zzp weld the flange on their pipe and you will need a bung welded to your intake and you will recirculte the air that blows off back into the intake. no maf relocate needed
option b: vent to atmosphere and will give you the most pshhhh. you have zzp weld on the flange attach your blow off valve to a direct manifold vacuum source. tell zzp you need the maf relocate pipe and extension harness and you will instnatly need a tune
DO NOT listen to anyone that tells you can just slap a bov and vent to atmosphere and tune around it.
TheReaper855 Feb 24, 2016 11:49 PM
Search engines are for losers. lmfao! Direct manifold vacuum? Never herd of this. Only thing ive herd is you need a maf relocation thingy.
wesg631 Feb 25, 2016 04:26 PM
You need a way to tell the BOV to open that is the vacuum source he is speaking of
Slowbalt2000 Feb 25, 2016 05:43 PM
seriously...search before you post
TheReaper855 Feb 26, 2016 08:59 AM
I'm good! If we all did that then the forum would be dead
blueLNFftw Feb 26, 2016 09:01 AM
Trust this man.
Psykostevo Feb 26, 2016 10:38 AM
A BOV and a Wastegate serve two different purposes. I think you meant "What makes the stock internal bypass valve better?"
If you plan to run the BOV as a recirculating BOV, I would have less issue with it. No reason to vent into your engine compartment and lose airmass during shifts. The stock internal bypass does not appear to be inadequate at doing its job.
Are you wanting to do the BOV just for the noise? I am curious what your reasoning for wanting to do it is. I see a lot of people on here buying superficial mods just for the sake of having more mods than someone else, or because their buddy with an unrelated car has those types of mods on theirs and they want to hang out and feel cool together.
Psykostevo Feb 26, 2016 10:41 AM
Who do you plan to have do your tuning? Owning HPTuners does not make someone a tuner, and this industry is not a level playing field.
TheReaper855 Feb 26, 2016 01:01 PM
I am going to be getting a terminator tune.
TheReaper855 Feb 26, 2016 01:02 PM
Yep just doing it for the noise pretty much.
blueLNFftw Feb 26, 2016 01:43 PM
You been in contact with him?
He has disappeared from here.
TheReaper855 Feb 26, 2016 01:46 PM
My cobalt group knows him. Haha
tomj77 Feb 26, 2016 02:45 PM
Km043 is just as good if not better and much more responsive
Snail_SS Feb 26, 2016 03:14 PM
That^
TheReaper855 Feb 26, 2016 03:55 PM
Good second option then if stuff doesn't work out.
