what is ''the pill mod"?
just like the thread says....
what is ''the pill mod"? |
putting a welding tip in the boost line under your turbo.
whats this do? slow down vacume
It delays the opening of the wastegate to increase boost & torque in the midrange. Not for peeps that can't toon for it. ;) You have to adjust DAL tables and disable overboost codes to keep from going into limp mode.
There is a thread on it in the HP Tuners 4 cyl forum. |
what power #s do you see with this?
Originally Posted by chevysssc
(Post 4472162)
its when you slip something in a girls drink that makes her easier to get to know.
(Post 4472162)
Haven't been to the dyno, but the size of the restriction varies the rate of the WG opening. .045 pill keeps me around 25psi tops. It still tapers off to 19 - 20 psi @ 6500 RPM depending on load. A manual boost controller works the same way, but with this mod we still have control of boost with the Desired Airload table. |
Originally Posted by BeermanSSSC
(Post 4472170)
