2l pcm help
I'm pretty sure asside from some craked plastics that this pcm is fine. But i'm just making sure. I tried finding a pic of one to compare but couldn't find any good enough.
https://i1103.photobucket.com/albums...2/question.jpg is the section in red supposed to be blank like this? zzp said i could get some trade in as long as all the pins are there and i just want to make sure before i confirm everything. Thanks a lot guys. |
That PCM looks A-OK. Don't worry about the cracked plastic. As long as the connector is able to clamp on all the way its fine.
why didn't i just post this up here to begin with? it's been on cu for probably a couple weeks with no response.
Thank you very much for the help |
