3" downpipe to 2.5" catback
Generally speaking will a 3" downpipe bolt to a aftermarket 2.5" catback? Or is this something that will mostly depend on brand.
I don't think it depends on the brand.. I'm pretty sure you should be goor
thats my setup basically. ZZP longtubes 3in dp to a 2.5 mandrel bent back end.
I had zzp just weld a slip reducer to 2.5, and had the opposite end expanded to a ID of 3in and slipped it on and clamped it, and thats all there was to it. |
Originally Posted by 07SS_chick
(Post 6233678)
Do you mean a 3" through-out? That physically isn't possible. You will have to make some sort of flange to make it work. You can get a 3" DP that goes from a 3"-2.5" flange. That will work.
I hope I understood what you were trying to ask and answered your question. |
YES it will work, if the aftermarket cat-back bolts up to your existing stock 2.5" downpipe it'll fit.. order a downpipe from ZZP. I got my ZZp catted 3inch DP with a 2.5" exit flange welded onto it and a extra O2 bung and plug for when i get a wide band! i got mine on black friday and saved 30% tho :lol: Mine being paired up with a magnaflow 2.5" cat back system
They give you lots of options, 3 inch exhuast exit or 2.5inch bolt on, extra 02 bung for wideband or not, gaskets, catted or not catted. and i believe they use magnaflow catalytic convertors ZZPerformance - 3 inch Stainless Cobalt/Ion Downpipe # :twothumbs |
Originally Posted by DarkChild
(Post 6233723)
Originally Posted by 06cobalt racer
(Post 6234435)
yeah it will work, mine was like that for a little bit. it leaked more often though
(Post 6234626)
I had mocked mine up and didn't like the gap it had. I didn't mean to misinform anyone if it does actually work without leaking.
Originally Posted by SneakyMilo
(Post 6234635)
As stated... it will probably bolt up just fine but you will probably have to live with leaks. Why not get a DP with a 2.5" outlet?
i got long tube heads and gutted cat downpipe from vibrant that i hooked up to what i believe is stock 2.5 inch straigh catback... no gapping.. idk if that helps... prob not huh?
