Possible new Supercharger cooling mod?
Randomly as hell found this on facebook on a non-cobalt related page.
No idea who's car this is, the validity of installing a fan over the blower, what else is done, but thought this looked neat and figured i'd share for discussion.
Also hi guise
Attachment 10398
Also hi guise
Attachment 10398
Originally Posted by OzzyruleZ;7652329[B
]Phenolic spacer makes it so the blower barely gets warmer than ambient. [/B]Also doesn't look awful like a fan right on top of it
I've used both copper RTV on a bare phenolic spacer as well as the high tack spray on the paper gaskets. The high tack spray on the paper is definitely the way to go and you'll especially thank yourself when it comes time to remove it again. Yielded a good seal both ways. The steady state temperature of my blower and IM are way lower with it than without it. It takes a lot longer to heat soak sitting still too.
That's a member on here, he tracks the car, and IIRC claims it lowers the temperature of the blower (not the IAT but the blower itself) by 10 degrees.
As for the phenolic spacers, I installed a set for a local guy, best single cooling mod you can do. His car is on E85 anyway but I couldn't believe how low the IAT2 temps were with just a dual pass and spacers in our south FL heat.
