315ss #HondaHunting Lsj
#128
Is your dip stick blowing out?
#129
My dipstick didn't blow out even when I had my PCV port plugged off and had only a breather filter. But no it doesn't blow out now either. My oil stays clean a lot longer but I think a big part of that can be attributed to much less blowby with proper piston to wall clearance.
#130
Mr. B gave the best advise as usual but one most insert his local dialect to hear it.. Keep it stock and add a catch can inline off of the valve cover. I think a real modification would be a real pump. Weak electric smog pumps were engineered to only run 60-90 seconds during warm up so they would need a boost controller to turn it on and off. The only HP increasing solution is an engine driven pump that is $$$ and hard to fabricate on our engines.
Myself and the OP are in off road conditions requiring boost almost constantly. Our solution is to vent it all to atmosphere. We trade and get dirtier oil, lots of pollution, poor ring sealing and poor ring life. We get a cleaner air charge, cleaner inter cooler, TB and combustion chamber. Pick a poison.
cluelessk (09-15-2017)
#131
HGT "expert that likes to argue"
He blocked me for commenting on him asking for help and then arguing with everyone's advice.
I don't get it. I understand discussion and letting people know when they're so far off that we can't help(new members that don't try and look for info or don't even have a faint idea of what they're doing).
But arguing with people that have been specializing in our platform for years makes no sense. If you're so educated why join the forum?
#132
Then you received this advice from yet another member.
#134
You don't remember too well do you? You're referring to the guy that bought the dented up base model you made fun of and said if you want an SS buy an SS. I showed him how to put you on his ignore list. https://www.cobaltss.net/forums/new-...1/#post7662570
It was a blunt way of saying that. And solid SS's are getting cheap. Co-worker bought a TC sedan for 4k USD in better than average shape. Throwing parts at a beat base model is throwing money away.
#135
SS Cobalts aren't worth putting money into either. It's not an investment that you should expect to get any kind of return on. My blower is worth more than my whole car but every part I have put on it has been worth every penny. If you plan on keeping a car forever or for a very long time it isn't that crazy to want to replace your worn out parts with better parts.
