ABS light and P0433/P2229
Old Jan 17, 2010 | 04:17 PM
cobaltBlackss's Avatar
Hey guys,
Issue 1
I need some help figuring out my ABS problem. My pedal is completely soft and my ABS light is on. I bled the brakes using the x pattern starting with the right rear and the pedal regained it's stiffness. Once I turned the car back on it went soft again and the light remained on.
Issue 2
I am getting P0433 and P2229. I have checked the emmisions fuse and it's good. I have also switched the map sensor plug with the similar plug in the same bundle and I still get the codes either way. Just to verify, it's the p.e.d. 4 plug that goes on the map sensor right?
Issue 3
The temp reading on my dashboard display is not showing up.
Old Jan 17, 2010 | 04:28 PM
advise's Avatar
the outside temp reading or engine?
Old Jan 17, 2010 | 04:31 PM
Old Jan 17, 2010 | 04:34 PM
advise's Avatar
pull out drivers headlamp, pull out headlamp bracket, there's a green connector most likely its disconected
Old Jan 17, 2010 | 09:00 PM
I saw that connector there, but I couldn't figure out where it belonged. thanks.
Any insight on the ABS?
Last edited by cobaltBlackss; Jan 17, 2010 at 09:00 PM. Reason: Automerged Doublepost
Old Jan 18, 2010 | 02:41 AM
insylem's Avatar
so THATS what that thing is.
I Saw it when I installed my K&N intake...
Thought it was for the Airbag or something.
Possible hairline fracture in a brakeline somewhere...
Just enough of a crack to let air in.
Old Jan 18, 2010 | 01:31 PM
^^^ you may be right, but why would it be stiff after bleeding then soft when I start the engine?
Old Jan 18, 2010 | 04:08 PM
advise's Avatar
well it would go soft cause the brake booster vacuum would suck air in, just my guess
the connector goes on the backside of the headlamp bracket
Old Jan 19, 2010 | 09:24 PM
Old Jan 19, 2010 | 10:39 PM
ThiZo_19's Avatar
bleed the master cylinder, if it still gets soft...Possible leak, abs module faulty, drive without brakes...:P
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
