Aftermarket Heat Exchanger
Old Aug 22, 2006 | 07:31 PM
CobaltBurst's Avatar
So this purpose of this is to lower air intake temps even at high boost, and increase HP this way right? So there would be no benefit to have this before a tune than after right?
Just checking b/c i really want one of these but its going to have to wait until after my custom tune.
Thanks,
Ryan
Old Aug 22, 2006 | 07:37 PM
Ljavy17's Avatar
marking this thread.
Old Aug 23, 2006 | 07:58 AM
need an answer plz.
Old Aug 23, 2006 | 08:09 AM
06blackg85ss's Avatar
there would def be a benefit... it'll still lower your iat2's even with moderate boost.. check out www.cobalt-addiction.com . they got a nice kit thats moderatly priced and easy to install/... its under performance/forced induction
Old Aug 23, 2006 | 01:00 PM
yellowcobaltss05's Avatar
i was wondering about this upgrade too. will this give a slight increase in hp?
Old Aug 23, 2006 | 01:04 PM
Smokem10's Avatar
Yes, you will get more HP....I have a cobra H/E running in series with the stock h/e and all I can say is WOW....there is definetly HP gained from this mod....
Old Aug 23, 2006 | 01:10 PM
I'm running the H/E standalone and I can def feel an increase.
Old Aug 23, 2006 | 01:41 PM
but my question is... is there a benefit of having a tune AFTER the install? Or either way its the same?
Old Aug 23, 2006 | 01:42 PM
nah... computer should make up for it... just makes the air denser... if your stock anyway... If modded I'm sure you could add a little timing and play with the afr,,,
Old Aug 23, 2006 | 01:59 PM
k i figured not, im not stock but i think the PCM will adjsut for the lower air temps etc.
Old Aug 23, 2006 | 02:00 PM
also im thinking of a Nitrous Intercooler spraying system instead of the alchol/meth system, anyone tried this with our HE?
Old Aug 23, 2006 | 02:02 PM
Alky/water works damn good... heat exchanger sprayer might not work too good because it is a water-air setup... might help a little... but I saw a huge decrease in IAT2 with the meth inj
Old Aug 23, 2006 | 02:06 PM
do you necessarily have to tune for the alch/meth?
Old Aug 23, 2006 | 02:23 PM
No you don't... to keep it safe... but you could
Old Aug 23, 2006 | 02:30 PM
so how exactly does it work? just sprays into your intake creating extremely cold temps?
Old Aug 23, 2006 | 02:39 PM
yeah... it also raises you octane as high as 116-120 from what ive read... so you can run a race gas tune (ie I"m running 24deg of timing) that and the benefit of droppin you temps by up to 80deg.... ask the LI peoples... my blower is ice cold after hard runs... I love it
Old Aug 23, 2006 | 02:44 PM
how much of the mixture do you go through? daily driving/ track? how often do you fill it? where do you get it?
Old Aug 23, 2006 | 02:46 PM
ummm under normal driving it doesnt inject on mine... but since I drive like a nut I go through a good amount (sometimes up to a 1/2 gallon a day, I do a lot of parts testing)... good thing is you can run -20 windshield washer fluid which is 1.99 a gallon. I personally mix my own up, usually 50-60 meth/distilled water
Old Aug 23, 2006 | 02:51 PM
hmmm thanks for the info, im defintely getting the HE, i love the way it looks, are all of them spray painted Cobalt Addiction? or can u custmize it?
Old Aug 23, 2006 | 02:54 PM
no just e-mail him... hey have a machine that cuts out the stencils... I'm sure he'll put whatever you want... if you check out my pics I posted today there is a good shot of it...
Old Aug 23, 2006 | 02:55 PM
https://www.cobaltss.net/forums/pictures-videos-64/some-pics-weekend-29909/
Old Aug 23, 2006 | 02:56 PM
sweet thanks for your help!
Old Aug 23, 2006 | 02:59 PM
not a problem
DarrenGC
Dec 24, 2021 01:55 PM
n20saturn
Sep 30, 2015 12:26 AM
metroplex
Sep 27, 2015 07:48 AM
jmelton327
Sep 26, 2015 10:04 PM
Extreme Dimensions
Sep 24, 2015 07:51 PM
