ALERT**Dipstick popping out? Here is solution!
PIP3983 - can be accessed through the service department.
Engine-Engine Mechanical (07 - Poor, Performance, Power, 13 - Check Engine Light Code, 14 - Leak, Foaming Condition, 20 - Loose, Broken, 21 - Fit, Appearance, Clearance, 26 - Alignment, 35 - DTC, 44 - Intermittent, 45 - Lamp On) Subject: Oil Leak from Top of Dipstick - Replace Intake Manifold Gasket - keywords Accel Acceleration CEL Crank Crankcase Dip Engine Excessive Hard High MIL P0171 PCV Pressure Repeat SES Stick WOT Models: 2005-2006 Chevrolet Cobalt SS 2004-2006 Saturn Ion Redline with 2.0L Engine (VIN P - RPO LSJ) The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI. CONDITION/CONCERN: On rare occasions, the engine oil dipstick may become unseated on hard acceleration, resulting in an engine oil leak. If the engine is operated long enough like this, a P0171 DTC could set due to the engine ingesting unmetered air. This concern is the result of excessive crankcase pressure on hard acceleration. This crankcase pressure may be the result of an intake manifold gasket concern that allows supercharger boost pressure to bypass the intake manifold gasket where it seals around the PCV orifice, which is between the #2 and #3 intake runners. RECOMMENDATION/INSTRUCTIONS: If the SI diagnostics do not isolate a cause for this concern, replace the intake manifold gasket using part number 12597855, which contains an updated sealing surface around the PCV orifice. This part number, or any future part number, is designed to address this concern. Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. :twothumbs :twothumbs :twothumbs :twothumbs |
i know that i hate it when my dipstick pops out on its own
Didn't you just use a ziptie to keep ur stick under control? I think your idea is better than GM's. :)
tee hee
plus I am removing the IC soon for the dual pass anyhow so having the new gasket is a given!:twothumbs |
This problem only started after the dealer removed my intake manifold for a repair. They must have screwed up my gasket somehow.
Duct Tape.......
it fixes everything.... |
Too bad that updated PN will not register on any of the GM parts web sites.
gasket.....my whoe intake manifold was replaced b/c of this.
SS SC Cobalt, I'm not sure, but I don't think you have to remove the manifold to replace the intercooler end plate.
Glad to hear that it is the manifold gasket and not broken ringlands or bad PCVs.
the cores are unable to be removed in car... |
Originally Posted by p7x
not bad PCV but I think its a good idea to modify the PCV for extensive modding.
I modded the pcv on the srt, but a lot dont and have few problems:twothumbs |
Gaskets are on order and will be up on CED first part of next week.
Its nice to know GM is listening to us when we forward them some of our problems and are getting back to us with solutions. |
Its nice to know GM is listening to us when we forward them some of our problems and are getting back to us with solutions. :lol: |
this happened to me once, GM gave me bigger orings, now i have to almost twist the dipstick when i take it out, its in there pretty good.
I'm on im me :):twothumbs |
how much would these gaskets run, i wanna put this sucker on for when its time for me to mod more and the blower has to come off;)
anybody know how much this new gasket costs??
Nate |
New Improved intake gasket
Here is a link to the new gasket on CED
Click here |
New Intake Gasket
had to bring this back, needed the PIP info.
Originally Posted by 06black
(Post 1069182)
Nate |
| All times are GMT -4. The time now is 04:56 AM. |
