Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LSJ Performance Tech (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/)
-   -   Anyone know why this spring is here? (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/anyone-know-why-spring-here-324262/)
Henry3959 May 19, 2017 01:19 PM
As I went through the M62 I had to ponder the purpose of this spring. All it does is puts a slight load on the bearings and being fairly high speed bearings they are not extremely tight and could use a little load. It's not a counter thrust spring as there is no thrust created. The rotor gears are spur cut which gives us that awesome whine. That bearing has the largest amount of clearance and I could see it trying to walk in the housing which that spring would aid in keeping it going the correct direction into the coupler but the front bearing has a great press fit.
If you haven't replaced these before, the coupler drive has to come off to remove the bearing.
https://cimg6.ibsrv.net/gimg/www.cob...7f9ac2bf54.jpg
