Ariel Atom: Timing Chain Tensioner? HELP!
Fired up the Atom yesterday and heard this...
I have a exhaust leak so I know some of the sound is coming from that but it sure sounds like my timing chain is out of wack. Anyone else experience this? Motor has 7200 miles on it. I haven't done a compression check yet.
Any help would be greatly appreciated. Thanks!
I assume you're talking about this one? Ecotec Timing Chain Tensioner 12608580
Can it really go bad after just 7k miles? I'll prob run a compression test and drain the oil just to be sure nothing else is going on.
Thanks Lee,
It is odd it went bad so early but the original timing chain tensioner was ****. its a known problem on all LSJs. Easy to swap
Right on, thanks. I really appreciate it. Is there a how-to article that you'd recommend? I did a quick search and found a ton (some of which don't seem viable).
Yeah, it's pretty fun but you have to be willing to answer the same 20 questions over and over and over. You get used to it but there have been a few times where I've been tempted to answer with false information just for fun. hehe
Sweet. Yeah, I never really got into the drag scene but have been out to Sacramento Raceway a few times to watch. Always makes me want a old school muscle car.
No Problem. You're right, most videos are all k20/k24.
Finally got around to install the new tensioner today and I can't get this thing to reset (spring out) to save my life. Tried banging the back of it with a hammer, using a small plastic piece to hit the chain and even tried resetting the tensioner so its not fully locked into the unsprung mode. Nothing is working and I'm starting to lose it! Any suggestions?
i dont know about an atom but in a cobalt you can depress the gas and clutch and start it to turn it over in flood mode and it wont start but it will build oil pressure to reset it. On an atom you may have the same. If not pull the plug on the coil packs the fuel relay and turn it over for 18 revs.
I find it funny that my posts were scoffed at when I went through all my timing issues. Yet here is another person with a timing issue. I am a pro at setting the timing up now. Done it like 5 times. Had a bad tensioner, replaced and retimed, then I had a bolt break on the tenisioner, replaced it and upgraded the bolt to a 10.9 metric. Used heavier grade oil (10w30) to up my oil pressure for the tensioner in higher rpms which has seemed to help a lot. But i am almost done with my new engine breaking I am running 5w30 again. I have lots of vids and post around here of all the timing stuff I have done. Its often talked about but I am the only one that put time into my issues and posted my results.
ah yeah I had the old one like that too, take off the valve cover and stick a rubber handled tool down there and tap on the guide pinching the chain between the rubber handled tool and the tensioner, you should get a satisfying snap into place. Mine worked this way when it was the revered style where you can see the latching and spring mech.
1) why can't I just install the damn thing with it expanded out if I make sure the notch is aligned correctly? (see picture)
2) Do you always need to check the timing even though I zip tied the cam gears and chain?
I can't answer your first question, I haven't tried that before. However the 2nd one, I would at least spin the motor through a full cycle by hand to make sure you're not going to smash your valves. My buddy did the bungie cord method at some point when he pulled the head or cams, he stuck it back together and just cranked it on his 2.2 L61 motor, bent all 8 exhaust valves.
"An ounce of prevention is worth a pound of cure." -Benjamin Franklin
You did the Zipties though so I think you should be alright.
Found this too if you haven't seen it already. https://www.cobaltss.net/forums/how-...sioner-276244/ mentions getting the tensioner in there and then smacking the chain with something.
