Blower bearings = fuct
Just like the title implies, my bearings are fried. I ported the **** outta the blower, but had to regrease the bearings, apparently i used the wrong kinda grease or something. Before they went, I noticed
#1 IAT2 was 15-20 COOLER
#2 Was hitting 21 psi boost
My plans are to rebuild the eaton, new bearings, and bushings and such. I can't afford the whipple right now, plus tags kit isn't done, so even if I did buy a whipple I couldn't use it until tag finishes their adaptor plates and stuff. I used Mobil 1 synthetic high heat, high speed, heavy duty bearing grease. I don't know how that would fail? Maybe I packed them wrong
Yea i think it is from pushing the blower hard and overspining it, iam going to go to the dealer or order the supercharger oil two bottles, and get the sealant and see what i can do with that, but mine are grinding and squeek, kinda loud.
Were you actually shifting at 7400? How did you do that without floating the valves???
Last edited by Blown 4-banger; 02-13-2007 at 04:50 PM. Reason: Automerged Doublepost
