Boost?
Sounds about stock to me... with our altitude around here...
edit: at least thats what I get from reading the treads around here but someone with an ss im sure will post to conferm...
edit: 12psi is stock boost
btw google is your friend...
Is the supercharger pulley bolted on ? If it's stock there wont be any bolt's ... they are pressed on from the factory. It could be the gauge is off a little or the cat is starting to get plugged up some . What is the rev limiter set at? 6500 is stock 7000 is staged.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
