cam comparison
Old 07-29-2008, 11:36 PM
Raven SS's Avatar
then stop posting bogus **** without all the info..jerk
Old 07-29-2008, 11:47 PM
Rent me! per hour
Area47's Avatar
i posted the sheet comparing the power band of them all.
i posted the afr and timing to get those numbers.
how is anything bogus?
how i got to the timing levels? when the afr was at said posted point?
c'mon now, you know i don't give that info out.
::smack::
Old 07-30-2008, 12:18 AM
Josh@ottp's Avatar
Originally Posted by Raven SS
depends..tightening up the lsa between the intake and exhaust cams will cause more overlap which will move ur powerband up in the rpm range which by bryans power band would be a huge gain in traps
u dont have to adjust the cam gears in the same rotation thats the benefit of having adjustable cam gears
Thats not advancing the cams. and that won't necessarily up the power band.....lsa is just a byproduct of valve events, never judge cams by there lsa.
Witt's Avatar
Thank you much for the info. This should give a great comparison on the available cam options for the LSJ. The Cobalt tuner crowd owes you much.
Old 07-30-2008, 12:23 AM
ItalianJoe1's Avatar
Awesome to see the GMR cams making more power with much less tuning in them. I'd love to see the maps for an all out tune on the GMR's.
Old 07-30-2008, 12:28 AM
shsballa023's Avatar
I am so lost lol
Old 07-30-2008, 05:48 AM
Speedytec's Avatar
Nice curves!
Finally a real comparison of cams, thank you for this.
GM-R => 11.6 afr. 20 degree's of timing
272's => 12.0 afr 24 degree's.
Stock => 12.4 25 degree's of timing.
Looks like a pretty safe tune on those GM-R's. And nice to see that they have a really broad powerband.
Are you still running an unmodified head? A decent (exhaust) port job will probably raise that top end even more. Add a somewhat decent flowing inlet manifold and I would be very satisfied...
Old 07-30-2008, 08:01 AM
Doc
Doc's Avatar
very nice..thank you.
Old 07-30-2008, 08:25 AM
07SCCobaltSS's Avatar
thanks for the post area, i was wondering what the change from a stock cam would do for me
Old 07-30-2008, 08:35 AM
06black's Avatar
as the airflow across the head bumps, the timeing drops, just like it should.
advancing the stock cams, and even the GMR cars (tho it would take more advance) would cause a torque spike earlier, thus bumping power, however they would "fall off" sooner as well.
even with RPM being your friend on the dyno, helping you build power, the drop in air flow from doing this up top would be impossible to recover from.
also, as the overlap jumps, the "sooner" per say that you start to waste usable, "make me some power", air flow rite out the back with out getting any effect from it.
however on a turbo car........the result becomes a touch more friendly.
Old 07-30-2008, 08:44 AM
  #36
ralliartist's Avatar
put that pic in the cobaltss.net gallery. I can't see it cause of gov't computer. thanks.
Old 07-30-2008, 09:30 AM
  #37
freakta's Avatar
thanks for the comparo... now i need to learn some stuff, ill be back later
Old 07-30-2008, 10:12 AM
  #38
BlackSS/SC's Avatar
Nice Area! You're a trooper
Old 07-30-2008, 10:19 AM
  #39
freakta's Avatar
so ive been searching for a while and i cant find alot of info on cams. anyone have a good thread where i can read some info and get learned
Old 07-30-2008, 10:45 AM
  #40
Rent me! per hour
Area47's Avatar
as a retort to raven about the torque issue, and witt, for the drunk text last night about this.
if you look at the timing numbers i posted vs stock cams vs 272's you'll see why it's lower. could i crank the low end timing and get the torque back up above the stock cam numbers? yes. why didn't i? who says i didn't.
this is the closest numbers i could find without blowing any of them out of the water. i spent a good hour going through 150 dyno runs to get these three numbers for this comparison.
now, this is why the numbers are so close. more or less to show the effective power band of them all, not the peak power numbers from any of them. the stock cam dyno number IS ***** out, foot to floor engine screaming at 3 am on the rollers. it had nothing more.
thanks kids. i'll be here all week. try the veal
Old 07-30-2008, 10:48 AM
  #41
Witt's Avatar
I have no idea what you are talking about.
Old 07-30-2008, 11:09 AM
  #42
Raven SS's Avatar
technically speaking thats advancing one and retarding the other...maybe its different in the honda world but i dont see how it would vary IMO
Old 07-30-2008, 11:19 AM
  #43
Rent me! per hour
Area47's Avatar
uh huh, sure ya don't
Old 07-30-2008, 11:30 AM
  #44
freakta's Avatar
anyone have a cam book i can read or a website i can go to to learn some more, i understand duration lift seperation... or was that ***** not cams.. anyways i dont get how haveing a certain valve open at a certain time does what to hp and tq and how overlapping them changes how things work....
Old 07-30-2008, 11:36 AM
  #45
ShortStack's Avatar
Once someone figures everything out... can they please nicelely place it in an pm and send it to me so i know what to get for my engine next? k thanks..
  #46
Raven SS's Avatar
www.honda-tech.com
Old 07-30-2008, 11:46 AM
  #47
Rent me! per hour
Area47's Avatar
www.howstuffworks.com
Old 07-30-2008, 11:48 AM
  #48
Raven SS's Avatar
^that was my next post haha
Old 07-30-2008, 11:57 AM
  #49
qwikredline's Avatar
Originally Posted by Area47
no, no their not.
i have the cams used in the time attack car. gm-racing. check chapter 6 of the build book.
newp. stock cam gears. i never bought them like i had planned on doing to fix the issue with the 272's.
flat is good.
take it from the guy who built the car and ran the car at the track, the build book is one thing; the cams came out and in the actual event it ran stock cams....thats it my friend you can argue all you want my information is based on what happened . I was there.
Old 07-30-2008, 12:00 PM
  #50
Raven SS's Avatar
which backs up my beliefs that adjustable cam gears is a better buy than cam shafts themselves
Quick Reply: cam comparison
