Cam timing chain guide bolts upgrade
Old 05-27-2013, 04:04 AM
OttawaMark's Avatar
You guys are really pushing the envelope of this block, and making some of the bigger vendors look small town cheap in comparison.
Awesome, keep it up and I'll be a buyer for sure!
Old 05-27-2013, 09:58 AM
mrbelvedere's Avatar
List the shear mechanical properties of the bolts since they are seeing stress at the threads (shear) not pulled by the head of the bolt (tensile).
Get a vendor membership if you are going to sell stuff. Support the board dont abuse it.
why don't you list the shear properties of your hardware store bolt and when your input is needed on other things it will be asked
Old 05-27-2013, 10:48 AM
noorj's Avatar
these are shouldered right?
Old 05-27-2013, 11:38 AM
Tjolley's Avatar
Yes sir.
Old 05-27-2013, 12:09 PM
c130aviator's Avatar
anyway...
PSI x bolt diameter 1/4" x PI for a M6 bolt then squared so...
150000 (verified by ASTM 10.9 chart) x .785 (square inches by root mean for threads) = 117750 -40% (shear is 60 percent of the bolts capacity since there is no ASTM standard) =
70602 lbs for my 10.9 bolt
You can do it for the ARPs (grade 12.9 equivalent).
The funny thing is mrb you were all against changing from the stock 9.8 grade in my thread but now you have changed your tune about using an even higher tensile 12.9 by arp than my 10.9. I certainly never ask for any of your opinion in my threads but there you are, all inconsistent and junk.
But this entire subject is invalid since the only reason the stronger bolts will help is that they can take more torque to tighten down without snapping them at 89 inch lbs.
The stronger shear force doesn't hurt.
Old 05-27-2013, 12:12 PM
Originally Posted by Tjolley
Ill have to call arp. I figured ppl on here were intelligent enought to know that the sheer is proportional to the tensile strength.
As much as i would like to contribute to this forum i was tryin to share wat is avaliable. I dont do this for much profit if any. If anyone has issues with this ill keep my findings and ideas to myself. And trust me theres plenty more in the works.
Good to hear. I wouldnt stick to with those numbers cuz every bolt manufacture is different and has there own aloys they use which can change the strength of the bolt alot thats y u should never look at the high end of the chart. The range for a grade 10.9 is 130,000-150,000. Arp has a tighter tolerance 170,000-180,000.
But my consern is the intake side chain guide bolts.
I think the reason urs broke was cuz the bolt was over torqued during assembly or was weakened before. The reason i say this is cuz alot of ppl dont have a inch pounds torque wrench and just wing it by feel. 89 inch lbs isnt alot of torque. Its very easy to over do it.
You come up with a good package it will be worth it just from the leg work it would take to source the parts, drill out the bushings in the timing tensioner, etc.
It would be nice to have a new option for failing timing components.
Old 05-27-2013, 12:45 PM
the funny thing is I was not against changing the bolts your bolt broke from fatigue
as for the replacement the hardness of the stock bolt is fine and dandy and using a harder grade bolt can be a downfall as they can be brittle from the process of hardening the iseal fix is a bigger diameter bolt with the same hardness as stock
hows that being all inconsistent and junk
this subject is not invalid
Old 05-27-2013, 01:09 PM
South Central *********
JapEatr's Avatar
Stock thread size for me
Old 05-27-2013, 01:15 PM
Powell Race Parts's Avatar
me to. and if the bolt breaks at 89 inch pounds the torque wrench is not calibrated or the bolt was already hurt.
Old 05-30-2013, 02:05 AM
100% METH's Avatar
Trevor,
Ronnie installed the bolt you made me for the intake side chain guide behind the bolt hole.
He said it installed perfectly
Nice work!
Old 05-30-2013, 02:49 PM
  #36
Tjolley's Avatar
Ur very welcome
Old 12-20-2014, 09:32 PM
  #37
TurboWood's Avatar
Are these bolts available anywhere? I can only find them on CED, but they are out of stock and appears suspiciously discontinued.
ARP Ecotec Timing Chain Tensioner Bolt Set 11588522R
Daniel
Old 12-22-2014, 09:50 AM
  #38
TStone's Avatar
contact "Mrbelvedere" on here. He is the one who had them made. You can get then directly from him. Good guy and easy to deal with.
Old 12-24-2014, 02:35 PM
  #39
Josh@ottp's Avatar
I have them in stock also.
Old 01-04-2015, 10:26 PM
  #40
Tjolley's Avatar
Alot of ppl order them from CED wait 2 plus weeks and seem to find this thread and end up buying from me. Im shipping another batch to our European friends across the pond tomarrow.
Old 01-04-2015, 11:36 PM
  #41
they dont wait 2 plus weeks
Old 04-25-2015, 10:06 PM
  #42
illest06SS's Avatar
hey whats up bro my guide bolt broke so I had to get it extracted when the shop did that they made my thread bigger so now I'm having an issue finding the bolt because of that spacer that holds the guide in place any suggestions on where I can get the bolt like this custom done
Old 04-25-2015, 10:13 PM
  #43
illest06SS's Avatar
broken timing chain bolt
hey whats up bro my timing chain bolt broke and the guys at the machine shop made my thread bigger to be able to extract the broken piece of the bolt on the cylinder head now I need to get a bigger size bolt but shape the same way with the sleeve that holds the timing chain guide and place you think you might be able to help me out
Old 04-26-2015, 12:06 AM
  #44
JapEatr's Avatar
yes private message MrBelvedere
im excited my new block is drilled to M8 for the larger bolts
Old 11-07-2015, 01:41 AM
  #45
WOLDEEB123's Avatar
Getting part
Does anyone know where I can get this upgraded bolt?
Old 11-08-2015, 06:04 PM
  #46
crateenginedepot.com 1877 441 5150 ask for tom
Old 11-09-2015, 06:17 PM
  #47
Daniel Baker's Avatar
I was curious if you still had these available? I need an M8 set. I PMed you earlier today.
Old 11-09-2015, 08:35 PM
  #48
I do but have not received any pms
Old 11-13-2015, 06:40 PM
  #49
Mr. Belvedere makes nice upgrade guide parts. An essential modification
Old 11-14-2015, 02:39 AM
  #50
YelloEye's Avatar
Any reason one would spring for the M8 stuff over the M6 ones besides if you had to drill out a busted bolt?
Quick Reply: Cam timing chain guide bolts upgrade
