Car not boosting over 2psi, what gives? (Friends vehicele, modded)
Good friend of mine just purchased a SS/SC via auction. Car is modified, however he is not aware of what is all together modified, so that makes this a little hard....
What I know: Car has a smaller pulley set (I dont know what size) Car has what appears to be a stock Cobalt LS/LT muffler on it He says that no matter what the car won't pull more than 2psi boost, and there is NO check engine light. Im not really sure what it could be. Boost solenoid? Bad supercharger to manifold gasket? Any guesses/suggestions? Thanks all- |
bad gauge?
is the car still pulling hard? did it suddenly lose boost? or is it just the gauge? they arent the best quality, and are known to crack up now and then. |
if its actually only getting 2psi, the boost bypass solenoid is not closing. sounds exactly like what happened when i played with the boost inhibit in HPTuners. (it leaves the solenoid open constantly to disable boost)
easy test for this, pull the vacuum hose off the back of the bypass solenoid. if it builds boost, then the solenoid is bad |
also make sure the belt is not slipping specially with a smaller pully
it has something to do with the bypass valve. had this issue for about...a month. lol.
Could be all kinds of things....
belt slip bypass valve bad tune....who knows... Not me that's for sure. |
Check the electrical connector that goes into the boost solenoid. The little black box the vacuum line goes to. If it's unplugged, you'll only get 2-3psi.
I appreciate all the input. I suspected the boost bypass solenoid first as well. I have no idea, and Im sure he does not, if the car has had any HP Tuners tuning done.
I also suggested belt slip. The car does NOT pull hard at all. I'll have him try the solenoid bypass and see what happens. Which line needs pulled exactly, IMAGES? Thanks, Chris- |
the boost hose popped off the top of the intake manifold on my old friends redline and he had the same thing, check that connection. it's under the fuel rail, behind the s/c.
lol @ Brian
This is going to get really bad really fast. :lol: |
sorry the pic is shitty. its pouring rain outside and chevysalesman conveniently posted that engine pic :lol:
https://www.cobaltss.net/gallery/fil...oostbypass.JPG |
Originally Posted by Bika
(Post 1659090)
LMAO!! :lol: Good luck with that.
One thing. Didn't Brian's car have an exhaust on it?
Originally Posted by 1gmfanatik
(Post 1659131)
Originally Posted by D4u2s0t
(Post 1659141)
did you sell a banged up car?
pm me one too haha
Broken NJ Cobalts FTW! lol
I'm actually quiet interested in the story aswell :)
my car did have a full exhaust on it. i can post pics of that as well
Originally Posted by chevysalesman614
(Post 1659282)
To the OP, we need more details on the car. year/color. |
well, the op is about 7 hours away, so i doubt his friend bought a car from jersey :lol: but i did the same, so i guess it's possible.
If he bought it at an auction, who knows where it ACTUALLY came from. lol
Originally Posted by damien
(Post 1659158)
He didn't. I'll PM you a link to el story.
