Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LSJ Performance Tech (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/)
-   -   CEL Codes (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/cel-codes-304627/)
WVU_SS Nov 28, 2013 10:53 AM
CEL Codes
Well to start off, happy Thanksgiving everyone.
So I came home from school last night (3.5 hour drive) and everything ran and seemed fine. Didn't do any sort of hard or aggressive driving.
Went to start it up to head out for a bit last night and it took 5 or 6 tries to get it started.
I went and pulled the codes this morning and I'm getting.
P0340-Camshaft position sensor
P0017-Crankshaft position correlation
Everything I've found on here comes with a plethora of other codes and it has always seemed to be another issue.
I'm going to check all the wiring connections here in a bit.
I'm leaning to a bad sensor or a bad connection as there was no unusual performance or sounds on the drive home.
I'm really glad this happened at home......away from all my tools and more mechanically inclined friends.....:cussing:
Thanks for the help in advance guys.
TStone Nov 28, 2013 11:03 AM
Could be a bad crank sensor.
Could have jumped time.
Try unplugging the cam sensor and starting it
WVU_SS Nov 28, 2013 11:06 AM
Once I can get it in my garage I'll try pulling the sensor and starting it. What would I be looking for it to do?
And if it jumped timing wouldn't that have been something I noticed
TStone Nov 28, 2013 11:09 AM
When you finally get it started, does it seem to run normal?
WVU_SS Nov 28, 2013 11:12 AM
It seems to run just fine i only moved it a few feet before shutting it off last night. I didn't want to get stranded anywhere so I just left it at home. The little distance I did move it, it seemed fine, nothing sounded of, nothing felt off. I'm gonna go take it for a short drive now.
WVU_SS Nov 28, 2013 11:25 AM
So I just got back in. I couldn't get it to enter limp mode as I've read should be happening.
Its weird. It almost sounds like an rc car at times when decelerating and idling. It also sounded like a bad timing chain tensioner, however the tensioner is decently new. Also the idle seems a bit off. I don't know if its because of the codes or not however. The weird thing is that this all seems to go away once the car gets a bit warmer.
TStone Nov 28, 2013 11:36 AM
Do you have anything to clear the codes?
WVU_SS Nov 28, 2013 11:38 AM
Yup. I got a reader that will clear them.
TStone Nov 28, 2013 11:39 AM
Try clearing them and see if either come back
WVU_SS Nov 28, 2013 11:47 AM
Just went out on a short drive. Neither came back on. It still took forever to start so I'm now leaning towards a starter or battery going. That would cause these codes to appear I've read.
TStone Nov 28, 2013 12:11 PM
Well you can get starters pretty cheap if you wanna just throw some parts at it
mrbelvedere Nov 28, 2013 12:20 PM
this is the performance section not the my car is broke section you need to post this in problems and service
replace the sensor if that does not work retime the sensor housing and or engine
WVU_SS Nov 28, 2013 12:20 PM
Haha I might end up doing that. About once a month it has a starting issue, however this is pretty bad.
WVU_SS Nov 28, 2013 12:22 PM
And i'm sorry. I didn't know if there is a difference between the models. If a mod sees this, could i get it moved??? Thank you! Sorry mrbelvedere
