cracked header? need help
last night, i was making a few runs against my friends civic Si for the fun of smoking him... then i noticed my car was sounding like it had a whole in the exhaust and shit was rattling every once in a while. so i got under my car today and couldnt see anything wrong really untill i saw cracks where each bolt that mounted the header on, they are just straight cracks tho, so im not sure if the header is in fact cracked or the stock header is like that. im kinda new to this shit, so try and help me out.
If it is cracked enough to leak then soot will build up in that area. You should be able to hear and smell the leak too!
doesn't sound good....haha
edit: wrong section? |
moved.
post up pics.
There's a good possibility it's the flexpipe that's split. Without pics, it's hard to say, but check the flex section carefully. My Redline is bone stock and the flexpipe split in half with only 30,000 miles on it.
im pretty sure now that i see that pics that it is the problem, and damn its rusted.
http://i27.photobucket.com/albums/c1...Picture506.jpg |
That is a normal expansion joint that was built into it from the factory.
I see no sign of leakage! |
Originally Posted by FunkyStickman
(Post 2074021)
were exactly is the flex pipe? im guessing the coiled looking pipe that connects the header and downpipe?
that would be it
Originally Posted by Nussle
(Post 2074024)
http://i27.photobucket.com/albums/c1...Picture506.jpg My stock manifold, you can see the expansion grooves at the bottom https://www.cobaltss.net/gallery/fil...0/dsc02471.jpg Stock downpipe, the flex pipe is on the far right, I would check there https://www.cobaltss.net/gallery/fil...0/dsc02469.jpg |
Man you guys' shit gets hella rusty back east! Mine was still almost new looking!
You should be able to see lots of black soot near the leak area. |
