Detailed LSJ Build up!
Old Oct 6, 2008 | 11:11 AM
  #101
Omega_5's Avatar
Originally Posted by Witt
Sorry, was three sheets to the wind last night, leave out the reference part. Back when I was new on this forum one person from on the redline forum did exactly that with a vacuum barb drilled and tapped into the back of the bypass pipe on the manifold. His measurements were used in math in the same thread we debunked a few stating an M90 swap was a good idea.
Ah... that one makes sense... if it's tapped in pre-cores, though the bypass valve.
I thought you meant the actual line to the bypass actuator, which is post-cores.
Old Oct 6, 2008 | 11:13 AM
  #102
Z Speed's Avatar
Good to hear on the engine, sucks about trans though. If I have trans problems in the future I'll probably end up cryoing the quaife 6 speed set.
its not really the gear set im having troubles with. its the case. that front mount is so under braced that it seems to give way at anything sudden.
I was as the track and sliped my exedy as much as possible and all it took was 3 wheel hops and it was done.
its rather sad imo.
on a good note my car would of been in the 12s if i could of gotten off the line with a good 60... was trapping close to 110 every run
Old Oct 6, 2008 | 11:26 AM
  #103
Witt's Avatar
There might be a vendor offering rotated mounts soon along with steering rack shims, basically a setup similar to the time attack car. I'm not sure if it would help with the issue you had or not but changing trans mounting geometry may.
Old Oct 6, 2008 | 11:39 AM
  #104
Blown 4-banger's Avatar
Originally Posted by WSFrazier
So what happened to your original motor?
Also, keep the 272's, and ignore the GM-R's. You could technically get away with ditching the cam sensor, and using a 2.2 shortened exhaust cam. Just need to plug the head.
How difficult is that to do? When I do the GT35R on mine, I'm honestly thinking about getting the GM cam blanks and getting them ground to the 1400 hp ecotec spec .499" lift, 247 duration @ .050", 117 LSA.
Old Jan 15, 2009 | 12:13 PM
  #105
red_line_cobalt's Avatar
ok so its been a while since i have posted in my little build thread here haha.
the motor was built up and put all back together... i put it in the car and she started right up. how ever when i gave it alot of throttle she blew smoke out the back and lost power. then it started to burn oil.....
so now i have the solution to the problem.... when trying to do a compression test i got perfect numbers in all cylinders. how ever she failed the leak down test horribly. then i hooked the line up into each cylinder and blew into it. i was able to blow right threw (yeah i was blowing mt motor haha) so i realised that the cams were over lapping.... so after talking to a member on here who also ra these cams he said to retard the exhaust cam 3 degrease. and then i realised that the oil was getting burt because i burned my valve seals with all the unburt gas coming out...
so i just need to put in new valve seals and adjust my cams.
so now i have added more to the build.
valve seals (again lol)
new valves
brass valve guides
GM adj cam gears
Old Jan 15, 2009 | 12:24 PM
  #106
victoryss's Avatar
Show pictures of your exhaust ftw
Old Jan 15, 2009 | 12:29 PM
  #107
i will have to take some... i also got to take pics of the motor in..... i have a red valve cover now too.
Old Jan 15, 2009 | 12:37 PM
  #108
victoryss's Avatar
I have a black powder coated valve cover. Looks awesome.
  #109
06CobaltssOrange's Avatar
this build looks very interesting keep us posted
Old Jan 15, 2009 | 12:38 PM
  #110
ls1fbody's Avatar
Haz l33t wheelz.
sounds sexxay. i may steal your parts list when i can afford it. expect PM's in the future. focusing on suspension at the moment.
Old Jan 15, 2009 | 01:11 PM
  #111
victoryss's Avatar
It is I am going to see this thing in person this weekend. If there is missing parts afterwards blame ls1 HAHAHAHAHA jk
Old Jan 15, 2009 | 01:15 PM
  #112
noproblem man.... i just did some suspension stuff too...
eibach sportlines
Koni struts (not in yet)
dc strut bar
TTR rear sway bar
GMPP sway bar end links
what you got?
haha after you leave my car is all disassembled
Last edited by red_line_cobalt; Jan 15, 2009 at 01:15 PM. Reason: Automerged Doublepost
  #113
ls1fbody's Avatar
Haz l33t wheelz.
don't blame me for ****....
Old Jan 15, 2009 | 01:16 PM
  #114
victoryss's Avatar
You have been hiding lately ls1 how is things in the dessert!
Old Jan 15, 2009 | 01:19 PM
  #115
ls1fbody's Avatar
Haz l33t wheelz.
eibach sportlines
dc strut bar
TTR rear sway bar
what you got?
at the moment, K-Sport coilovers.
but... Powell Motorsports is building me a custom hub swap, 114.3 bolt circle, grand am hubs, SS/TC knuckles, SS/TC axles, a new time attack car twb, with integrated adjustable cromoly sway bar. Stainless steel brake lines and SS/TC front brembos, and eventually PFC floating rotors. I may have left something out, but thats the gist of it.
Old Jan 15, 2009 | 01:21 PM
  #116
nice.. i want to switch over to the KSport coil overs.
i also have the stage 2 axles from the drive shaft shop
  #117
ls1fbody's Avatar
Haz l33t wheelz.
haha, not hiding, been a little more busy that is all. that and workchat has a new crowd.
Old Jan 15, 2009 | 01:24 PM
  #118
blackss2.0's Avatar
if ur gonna spend all that money than u def need a dif form of f/i. If u dont, ur gonna spend all that money and wont even have 300 whp with the eaton. Go turbo or twin charge. Ditch the eaton and dont get a tvs. Go twin charged!
  #119
ls1fbody's Avatar
Haz l33t wheelz.
well, a little birdie told me that asymmetrically stiff axles are nicer to your transmission and reduce wheel hop. Aka, one stocker, one stage two. Now, not sure if the TC axles are that way, but i will find out.
Old Jan 15, 2009 | 01:26 PM
  #120
victoryss's Avatar
That it does and I am not sure about that new crowd.
  #121
as i have said many times before... if i liked turbos i would.... and turbos are not gods gift to cars as said before by others
i ca better you anymoney right now i am over 300 WHP right now with my M62.... and at a later date i will switch to the harrop... and twin charging is dumb and a waste of money!
Old Jan 15, 2009 | 01:29 PM
  #122
victoryss's Avatar
Uh oh I don't want thread lock lets keep the fighting to a min.
Old Jan 15, 2009 | 01:31 PM
  #123
ls1fbody's Avatar
Haz l33t wheelz.
you have no idea what you are talking about. please go away.
the fact that the only twin charge kit is made by ZZP should tell you to stay away from it.
also, some like the challenge and power delivery of building a supercharged car, why do some people not understand this....
Old Jan 15, 2009 | 01:33 PM
  #124
victoryss's Avatar
also, some like the challenge and ower delivery of building a supercharged car, why do some people not understand this....
Well said.
  #125
ShortStack's Avatar
Yea you obviously have no idea waht goes on with a twincharged car.
You know alot less than you think you about HIS car.
