Detailed LSJ Build up!
Old Jan 15, 2009 | 01:40 PM
  #126
red_line_cobalt's Avatar
calmed down... thanks guys. haha
Old Jan 15, 2009 | 01:43 PM
  #127
victoryss's Avatar
Yeah we don't want another computer throwing incident. hahahahahaha
  #128
ShortStack's Avatar
i love how he says ditch the eaton, but go twincharged .. lol..
  #129
victoryss's Avatar
That's classic hahahahahahaha
Old Jan 15, 2009 | 01:47 PM
  #130
ls1fbody's Avatar
Haz l33t wheelz.
what do you guys think of these....
https://www.cobaltss.net/forums/wheels-tires-96/i-can-has-wheels-150641/
Old Jan 15, 2009 | 01:52 PM
  #131
victoryss's Avatar
I love them. I was jealous so I didn't respond when I looked earlier.
Old Jan 15, 2009 | 01:57 PM
  #132
i kinda like them.... actually i really like them but am not sure if i could pull it off on my car... even with a red stripe
Old Jan 15, 2009 | 02:01 PM
  #133
ls1fbody's Avatar
Haz l33t wheelz.
haha thanks gents.
Old Jan 15, 2009 | 02:02 PM
  #134
pssst its the same link....
Old Jan 15, 2009 | 02:04 PM
  #135
ls1fbody's Avatar
Haz l33t wheelz.
i actually think your wheels tie into your car really well, I've seen them on other cars and didn't like them, but your car, well, i don't see any other choice.
Old Jan 15, 2009 | 02:12 PM
  #136
thanks bro
here you go... pics....
Last edited by red_line_cobalt; Jan 15, 2009 at 02:12 PM. Reason: Automerged Doublepost
Old Jan 15, 2009 | 02:18 PM
  #137
cobaltBlackss's Avatar
Did you decide to go with darton sleeves? That's what failed on my ported engine rebuild. I cracked my # 3 sleeve. What pulley size are you planning on running? I wouldn't go over 16lbs without some serious cooling mods.
Old Jan 15, 2009 | 02:28 PM
  #138
qwikredline's Avatar
Originally Posted by Plastic
They used comp to do the grind, GM provided the cams for them. I think we were just talking about 2 different cams. I was talking about the GM R ones that Area and ItalianJoe used. They were the ones that were designed for the time attack cobalt. That were never made available to the public for purchase until this summer when GM racing decided to clearance out their LSJ stuff to make room for their LNF stuff.
And I think you were talking about the GM Performacne Parts cams that will fit the lsj but were designed for the 2.2. That comp can make for anyone, so since they are essentially for the 2.2 not the 2.0 the cam sensor won't work if you put them in the lsj.
btw sorry for cluttering your thread with this confusion that didn't need to happen.
The time attack cobalt raced and won the time attack shoot out in Nov. 2005 with stock cams and GM adjustable cam gears....just sayin' ...
Originally Posted by ls1fbody
well, a little birdie told me that asymmetrically stiff axles are nicer to your transmission and reduce wheel hop. Aka, one stocker, one stage two. Now, not sure if the TC axles are that way, but i will find out.
TC axles are bigger than a duramax 4x4 front axle shaft
Last edited by qwikredline; Jan 15, 2009 at 02:28 PM. Reason: Automerged Doublepost
Old Jan 15, 2009 | 02:32 PM
  #139
i have alot of cooling mods... Front mount HE, dual bypass, meth.... more...
Old Jan 15, 2009 | 02:41 PM
  #140
But did you go with the sleeves?
Old Jan 15, 2009 | 02:42 PM
  #141
negative... no need...
Old Jan 15, 2009 | 02:43 PM
  #142
Thats what I thought too... However I wasn't running meth at the time so that could have been my down fall.
Old Jan 15, 2009 | 02:49 PM
  #143
its could be done for reassurence but ot really needed
Old Jan 15, 2009 | 03:05 PM
  #144
victoryss's Avatar
do you want a 3rd to blow up on you? Use the sleeve man use the sleeves hahahahahahah jk
Old Jan 19, 2009 | 02:54 PM
  #145
Any updates?
Old Jan 22, 2009 | 01:15 PM
  #146
victoryss's Avatar
I think he has the motor in and is parading around like he is tough ****.....jk but he does have the motor in from what I know.
Old Jan 22, 2009 | 01:53 PM
  #147
motor is in.... still have to adjust the timing a bit cuz i have a bit of valve over lap... then i need an oil catch can cuz i am sucking oil through the PCV system with all the boost i am pushing..... but she does run fine....
oh and i am tough **** haha
Last edited by red_line_cobalt; Jan 22, 2009 at 01:53 PM. Reason: Automerged Doublepost
Old Jan 22, 2009 | 01:59 PM
  #148
WSFrazier's Avatar
What pulley are you running that you are pushing all this "boost"?
Old Jan 26, 2009 | 11:55 AM
  #149
i have the 2.6 and the 2.7 i am currently running 2.7 and thinking i will stick with that.
UPDATE: cooling! how i am cooling all this.
1:meth injection
2:Heat exchanger
3:Option b tank
4:Single pass manifold (custom made)
5:Thermal wrap the intake
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Jan 12, 2016 12:01 AM
Sep 27, 2015 08:53 PM
