Diamond Racing Pistons arrived today.
Originally Posted by cavy9psi
if the stock rods are forged your good...id double check, well boost away if thats the situation...has anyone heard on anything on other superchargers that have more potention output working, i read the whipple pretty much isnt gonna try, anyone else
No need to double check, that information has been out for a long time. Get yourself a GM build book, and it'll tell you what parts the 2.2 and the 2.0 ecotec have. With the exception of pistons and valve springs, we're good untill ~600hp according to GM.
what about billet still cams?
I love billet cams, they are way stronger than cast, and you can run more spring pressure... but I'm kinda new at this 4 slamer tech...sooo...billet?
LSX RWD S/C conversion
Originally Posted by cobaltBlackss
What do you think about cam # 113250? It's operating rpm's only go up to 7k, so you dont have to screw with the ecu.
Originally Posted by 03gobluecobra
I'm guessing he is aiming for 8000 RPM.
Originally Posted by CobaltSS313
Is the cam you bought the same one that is on gravana's site or is it different
Originally Posted by CTCOBALTSSS
Congrats! How about a little how-to with some pics and dynos? I know...I ask for a lot.
Originally Posted by NGalaxyTimmyo
I'm hopeing to do that build book as well. I think I'm gonna be following your posts closely for a little while. When do you expect to tear apart your block?
On another note, this build is being done with a built in option to be able to drop in either the twincharged turbo or nitrious(least preferred) setup. I may even have a shop willing to do the build so their expertise can be showcased on the LSJ which will also benifit them with Cobalt\Red Line owners. I hope to get confirmation one way or another in the next 24hrs.
Either way the next few weeks are going to be hard getting to sleep, sort of like when I was originally waiting for my car. This is going to be a sweet ride
DAMN WHAT THE HELL DO YOU PLAN TO DO WITH THIS RACE/street MOTOR?!?! Are you shooting for 400 whp?
*EDIT also are stock LSJ pistons forged? They better be, that would be dumb on chevys part.
Might want to invest in some cutom Ferrea hollow stem valves.
The nice thing about the hollow stem is it makes the vales lighter and increases your RPM capability
and get the springs and retainers that gm sugests
400whp @8000 RPM corvete eater
As for the LSJ pistons no they are not forged which is why I bought the Diamond ones.
Originally Posted by Gory
...400whp @8000 RPM corvete eater
If the cam you have is not the one on gravana which cam on comp cams website is the one that is on gravana's site, or is the one on gravana's a completely different cam altogether? Sorry if this is confusing. Also if you take the redline up to 8K is there anyway you can pass inspection cause im looking to seriously mod my engine, id like to get 400whp but i still has to pass inspection.
The Gravana Comp Cams are only good to 7,000 rpm's where as the ones I am going with are good to 8,000. And considering the deal I worked out today I need the higher rpm's
#37
Originally Posted by Jmc007
Dammit you ordered the Stage 2 head, than the stage 3, now the stage 4 ?
#38
Originally Posted by victory_red_SS
Here is the link to the Comp Cams for the Ecotecs
http://www.compcams.com/technical/Ca...12-117_226.pdf
They are for the 2.2 with the shorter exhaust cam and wont fit- BTDT!
You need to call COMPcams in order to get a custom grind for the 2.0L with the longer exhaust cam for the cam sensor drive.
HTH
WopOnTour
#39
OMG Chevy is the biggest bunch of dumbasses on earth! Why the **** would put forged... EVERYTHING except the most important part! I can't believe this ****! I'm gettin those diamond pistons just to have a set a reliable pistons, I hate cast pistons and don't trust them even as a daily driver piston, I'v seen too many shattered cast pistons, what the hell were they thinking!?!?!? Especially while running 12.5 psi of boost! Im parkin my car til i get those diamonds, I also like the 10:1 comp ratio.
ok my rant is over, please return to normal conversation
#40
LOL
They seem to be holding up pretty well so far! - all the way to 22 psi!!
Hanvt seen an engine failure directly attributed to piston collapse yet- maybe other have?? (most I've seen have been valvetrain "trickle down" wrecks) and many of those due improper valve keeper or rocker assembly after upgrades
But to ignore upgrading them on a 400HP build up would be silly of course
Wop
Wop
#41
doesn't matter, I HATE HATE HATE cast pistons more than... ps... j... POOP!!! My friend had cast pistons in his 350 chevy, and suffered catastrophic falure due to piston shatter or collapse and ended up leaving two rods and hundreds of chunks of pistons on the highway. And he was just cruising, not even racing or speeding!
#43
Diamond Pistons
Originally Posted by MOD MONEY
nice ,too bad they dont have stock compression ratio
#44
Rods
compression ratio is important yes...but dont forget Forged internals can hold a lot more....thos pistons above are prolly good for 400hp if u have forged rods (dont get eagle)...it all depends on a tune too A/F is inportant part of an engines life....and those pistons will increase the hp in itself idn wat the Comp ration is stock but ull see decent gains from pistons...id get rods tho if u want to see over 300 play it safe man something has to give underhp....the piston wont but ur rods will slowly build...after the rods id work on the head....have fun, and take the time and do it right...
#45
Originally Posted by WopOnTour
Warning! None of these COMPcams will fit the 2.0L (*they removed the 2.0 in their NEW PRODUCT catalog)
HTH
WopOnTour
HTH
WopOnTour
I then asked how long to do a cutom grind and he said 1-2 days. He then adds they would then be sent to have the nittro coating done with a turn around time of 6-8 weeks
He said that even though they did the cams for the 300+ build they thought the 2.2 ones would work. So I say screw Comp. I will now go with the JBP Tri-flow, seeing as JBP will be doing major things to the engine anyways.
Way to go Comp Cams
